Off color question
kyvfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kyvfarmer Quote  Post ReplyReply Direct Link To This Post Topic: Off color question
    Posted: 25 Apr 2010 at 10:29am
Hi guys
     I have an old JD 4030 that I use few times inthe season ,I'ts been parked since October .Yesterday I went to crank it up and found when I pull the dipstick that the fuel have travel to the crankcase having 15 gallons of fuel plus the oil,what can be causing this? Thanks
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2010 at 10:49am
Either the lift pump, or cup seals on the injection pump drive-shaft. The flex ring is likely broken apart, plugging the return, thus blowing the drive seals. HTH, Ed.
