tire preference
alan-nj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan-nj Quote  Post ReplyReply Direct Link To This Post Topic: tire preference
    Posted: 17 Nov 2015 at 4:46pm
opinions.....which tire would you prefer for pulling?  and why?
first pic is a 13.6 safemark; old tire, hard, 23 degree
2nd pic is a 14.9 titan  short bar / long bar, pretty hard, not as old as safemark
if you prefer the titan because its a 14.9, which would you prefer if they were both same size?
If ignorance is bliss, than happy days are here again.
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2015 at 6:16pm
I don't like how long bar shirt bar pull. The 14.9 aspect is nice but the safemarks are good pullers. That's what was on my WC puller. .13.6x38 topcuts
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2015 at 7:29pm
my experiance is that old hard tires just dont get traction like new soft rubber dosnt matter if you are in the field or on the track  you can make tires hard with more air or wider rims to pull that side wall out and flatten the tread  dont know what rules say about rims
TennMatt1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TennMatt1 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2015 at 9:55pm
It really depends on track conditions but a hard tire is far better for pulling tractor. New and or soft tire lugs roll really bad then flick up the dirt and that piles up in front of the sled. Ive never till now heard of a new tire pulling better. I had a set on my tractor when I got it and actually watched a video of them in action versus a old decrepit wore out tire..The old tire pulled way further. unless your in mud or in a rice and cane feild there's no need for a lug because you don't wanna dig down,it lowers your pulling point. The list goes on and on. My preference personally would be the safeway because of tread pattern. Those 23's pull good.
1954 WD45
mike a View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike a Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2015 at 10:34pm
old worn out road sharp 45 degree stones,about 6-7 psi,15.5x38,be ready for traction!
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2015 at 4:58am
Never see the long bar short bars do anygood around here. I like the Firestone F&R
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fields Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2015 at 12:34pm
  I've been running whatever cheap to buy tire i can. The first 15.5-38s were firestone 45 deg. Then goodyear traction torque , I have pulled a set of 13.6-38 cut goodyears and have done well. But most classes don't allow cut tires. My colection of availible tires to try are 14.9-38 goodyear traction torque, firestone heavy duty field and road 15.5-38, and a pair of Armstrong 15.5-38 tires 30 degree. this next year im going to swap and or switch at least 3 sets of tires on 3 differn't tractors. To see if i can inprove or meet class rules.
This page was generated in 0.104 seconds.
