k361 |
AC puller
Topic: k361Posted: 15 Nov 2015 at 4:21pm |
does anyone know if the k361 18hp piston is the same as the 16hp?
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42266 |
Posted: 15 Nov 2015 at 10:06pm |
K 341 seems to be the same stroke as the 12 and 14 HP -just the bore size changes , so would think the bore would be larger in 18 HP but it is NOT - same size in both
Seems the specs are the same in both engines
Herb(GA)
Joined: 15 Sep 2009 Location: United States Points: 1039 |
Posted: 16 Nov 2015 at 12:11pm |
Valves and Cam
ACmowerguy
Joined: 20 Apr 2010 Location: Winfield, MO Points: 1210 |
Posted: 17 Nov 2015 at 6:38pm |
I believe the skirt is longer on the 18hp piston. I had bought one several years back as it was improperly labeled for a K341. I sold it on ebay a few years ago.
Edited by ACmowerguy - 17 Nov 2015 at 6:39pm |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4072 |
Posted: 17 Nov 2015 at 7:20pm |
stroke and pin hight may be diff. will check
norm[ind]
Joined: 29 Oct 2010 Location: bourbon,ind Points: 2992 |
Posted: 17 Nov 2015 at 7:41pm |
every thing is the same as 16 hp.--only difference is overhead valves--i have one i used for copetition- only made 3 yrs.--used too beat the twins also had more torque still have it in barn in a wheel horse
AC puller
Posted: 17 Nov 2015 at 9:00pm |
Read on a kohler site where the 16 and 18 were same bore. 18 had longer stroke.Cant find a rebuild kit piston rings,anywhere.
HudCo
Posted: 18 Nov 2015 at 9:38am |
quik look on part numbers they are all dif. but did not get into the actual measurements and specs.
