M3 automatic vs manual unload auger |
Wade (IA)
Joined: 12 Sep 2009 Location: Osceola, IA Points: 232 |
Topic: M3 automatic vs manual unload augerPosted: 10 Nov 2015 at 1:42pm |
Does the automatic mode work with auger going out and when it folds in? Is it controlled by the roller switch on the housing and the lever switch on the cradle? The auger has tried to turn on before it was fully out and I'm thinking it's one of the switches?
ryan(IN)
Joined: 11 Sep 2009 Location: Bluffton,IN Points: 789 |
Posted: 10 Nov 2015 at 1:55pm |
What do you mean by the auger has tried to start before its out? The automatic mode is just for swinging the auger out and in. You have to press the switch for the auger to start(assuming it has the electric/hydraulic control). If the auger is starting before its out either the roller switch is misadjusted or is bad. The roller switch on the swivel is what controls when the auger can come on. The switch on the cradle is just for the auger out light.
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62 |
Wade (IA)
Posted: 10 Nov 2015 at 2:53pm |
Ok, I'm betting the roller switch is my culprit
bradley6874
Joined: 05 Sep 2010 Location: salisbury md Points: 1349 |
Posted: 10 Nov 2015 at 6:11pm |
Fix it before you have to repair the auger because it started to soon and busted s...t up
Wade (IA)
Posted: 10 Nov 2015 at 6:35pm |
Too late, broke the knuckle u joint!
bradley6874
Posted: 10 Nov 2015 at 7:35pm |
sorry been there fixed that
Michael V (NM)
Posted: 13 Nov 2015 at 1:55pm |
on my L3 the auger swing is separate from the unload switch, if you leave the auger running when swinging back in the micro switch shuts off the auger, I never started unloading until fully swung out and always tried to shut auger off before swinging in
Jim NEIN
Posted: 13 Nov 2015 at 5:06pm |
Look that micro switch up on line.They are $7 on line and $56 at Agco
Wade (IA)
Posted: 13 Nov 2015 at 7:07pm |
It seemed to start before the auger was fully extended.i need to get the old switch off to cross a matching replacement.
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8457 |
Posted: 13 Nov 2015 at 8:51pm |
Wait... so on some combines when you push the switch for the auger out, when it gets out the auger automatically engages?
MACK
Posted: 13 Nov 2015 at 9:09pm |
No. Auger only turn on when you push the unload switch. If it comes on by it's self, you have a wiring problem. The limit switch keeps you from turning it on until the auger is out. MACK
CrestonM
Posted: 14 Nov 2015 at 8:47am |
Ok....I misunderstood. I thought that'd be pretty strange.
