WC crank bearing shims
JM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JM Quote  Post ReplyReply Direct Link To This Post Topic: WC crank bearing shims
    Posted: 23 Apr 2010 at 9:27pm
Are these still available or do you have to make your own? Tore my engine down today, all the rod shims are gone, 1 left on the mains.Thanks, JM
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2010 at 10:03pm
I think the shims are still available. I made my own because I had access to brass shim stock. Many people have line bore the block and re-sized the rods and completely done away with the shims.
WC7610 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC7610 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2010 at 11:27pm
After encouragement from Dick L, I just made main bearing shims tonight for a B engine.  I did a google search on brass shim stock and came across a conversation on this subject on Smokstak website for hit'n'miss engines and that K&S has the brass 4" x 10" sheets in various thickness.  I found my local Hobby Lobby carries this and got a sheet of .01" for 6.99 and .005" for $3.69 tonight.  Traced one of the old shims and will finish cutting them tomorrow.  I took 2 pieces of 1" oak scrap and drilled a hole in one board-lined up the traced bolt hole in the shim stock with the hole in the board-clamped the boards together to hole the sheet of shim and drilled the bolt hole for the shim.  Then cut the rest of the pattern with heavy pair of sissors.  For the .005" size, you can cut them out with a new blade in a utility knife.
Agco has these yet, but for mains are $5.05 each and 3 something for rod bearing shims.  I know this because as Dave Ramsey would say "I paid my Stupid Tax" ;)
Google K & S and they have a store finder on their website.  I went to what I thought was an "old time" auto supply store and they laughed at me when I asked for some shim stock.
Good luck!
Thanks
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2010 at 11:45pm
McMaster Carr has laminated brass shim stock available also.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2010 at 11:47pm
McMaster also has much of the K&S line which is most commonly found in hobby shops and some hardware stores.
Gerald J.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2010 at 6:34am
Be money ahead to replace the rod bolts and have the rods sized so you dont need shims. jmho
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2010 at 7:00am
on second thought this is jm the one who pulls? I  would have my crank offset ground to a  smaller rod that doesnt use shims and gain the stroke .
Edited by mlpankey - 24 Apr 2010 at 7:00am
powertech84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2010 at 12:13pm
I just got a set of rods resized for $40, couldn't see messing around with shims for that money. If you really want shims, i could problly help you out  for cheap if you want some of my used ones.
Edited by powertech84 - 24 Apr 2010 at 12:13pm
This page was generated in 0.153 seconds.
