B steering gear? |
TMiller/NC
Joined: 11 Sep 2009 Location: Lenoir, NC Points: 1776 |
Topic: B steering gear?Posted: 26 Sep 2009 at 7:18pm |
Will the Gemmer and Ross steering gear interchange? Thanks.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 88593 |
Posted: 26 Sep 2009 at 9:56pm |
the parts can not be mixed and matched, but you can take one box off and just slide the next one on. I have never had a problem attaching the arm, but have heard some say one of the output shafts is missing a spline for alignment. You might need to do a little "fix", but i have had no problems to date.
TMiller/NC
Posted: 27 Sep 2009 at 10:52am |
Steve (Ill) Thanks for the reply. Have never had a Ross open are they similar? From what I can tell from the IT repair manual the Ross looks a little more complex.. The '49 with the Ross gear is hard to steer, but if I loosen the adjustment from behind the starter it has quite a bit of loose motion in the steering. Was thinking of replacing with a Gemmer from a '39 I am restoring and at some point repair the Ross, however if the Ross is not to complicated I might just remove and repair and reinstall. Thanks.
