F11 farmhand loader on a WD
Craig77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Craig77 Quote  Post ReplyReply Direct Link To This Post Topic: F11 farmhand loader on a WD
    Posted: 06 Nov 2015 at 3:45pm
Looking to maybe install an F11 loader on a WD. I found one for sale locally. From what I have read online, it looks like there were brackets available to install on a WD. I may have to fab something up, but thats ok. Does anybody have any pictures? I am wondering how it gets around the fenders, hand clutch, and pedals.  Maybe the fenders have to come off? Thanks.
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2015 at 4:06pm
I think your rear wheels have to be moved out about as far as they go, then the resr will clear the fenders, we had a Dual and on that we took the fenders off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Craig77 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2015 at 7:25pm
Thanks for the input Jim. I ended up buying an F11. Here it is when I got it home:
I decided to initially set the rear wheels all the way out, and remove the fenders to start with. The F11 has a tubular structure that ties the vertical frame pieces together and allows for routing of hydraulic hoses from one side to the other. There is some adjustment in this and I set the vertical posts at the widest setting. Used a gantry type crane to pull it off the trailer and position it on the WD:
Ended up breaking some bolts due to rust. Gonna run to the hardware store in the morning to get new stuff. Hopefully will get it mounted up tomorrow while the weather is still good.
Does anybody have any instruction for how to bleed the hydraulic system?
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2015 at 5:50pm
just like mine will try to post a picture probly have to email them cant seem to post pictures last while  give me a call 435 230 0161 them f 11 s have to be the original  or first quick attach on the market
Post Options Post Options   Thanks (0) Thanks(0)   Quote Craig77 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2015 at 9:16am
Yeah, I feel like i could remove and install the loader pretty quick now that I have the axle brackets adjusted. Finished installing just as it was getting dark. Fired it up and the high pressure line from the pump has a bad spot in it. Leaked pretty good, but I was able to operate to verify the pump, valves and cylinders seem ok. Here is a quick video the wife took:
[TUBE]iZwMHbvK5yU[/TUBE]
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2015 at 11:29am
All the AC's I've seen with those long FarmHand loaders on them never had the fenders installed. We used a Du-All on our WD45D and the fenders had cutouts for the vertical frame. It also had the oil reservoir as part of that frame, which helped with the clutter. I watched a D19 sell with one one it, the nice fenders were sitting beside the tractor. I wound up making a deal with the buyer to haul the tractor for him and I took the fenders in trade.
ALLIS EXPRESS!
This year:
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2015 at 3:53pm
Should be able to really pile up the snow with that thing !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2015 at 9:34pm
I have a Farmhand F19 on my WD. It is a little different though I think.
Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2015 at 9:40pm
I hope I can share a few photos of how mine F19 looks.
photo rear
photo side
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2015 at 9:46pm
I've both seen and run the F11's on WD's and WD45's, they always worked great, but they all used to PTO pump on them. now that ain't gonna fit in yor connex box!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Craig77 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2015 at 8:43pm
Yeah, the fenders will not work without being cut. I may buy some reproductions and cut them up for when I have the loader on like you did with your Du-All.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Craig77 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2015 at 8:48pm
photo rear
photo side
Nice looking loader and tractor!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Craig77 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2015 at 8:51pm
I am wanting to install a pump between the motor and steering gearbox, driven off the crank. I have seen the Allis Chalmers pump setup that they sold with there loader. Something like that.
