Calling WD45 Gurus
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Topic: Calling WD45 Gurus
    Posted: 23 Apr 2010 at 7:40pm
I have a couple questions regarding this 1956 WD45. It's new (to me) and seems to be pretty much original.
1) What are the brackets (see photo) near the bottom of the fenders for?
2) Can the bent lift arm (see photo) be straightened? Recommendations?  Wonder how it got bent? (previous owner said it was that way when he bought it)
JohnThomas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnThomas Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2010 at 7:43pm
I'd take it to a first class welding shop where they can heat it, straighten and re-temper it. I've done that with fork lift arms.
Life is short...Make haste to be kind
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2010 at 7:47pm
Those brackets are most likely for a heat houser, a canvas winterfront if you will. Too hot going into the wind and froze to death going with the wind.
The lift arm could probably be straightened in a good press, but it would probably be the easiest to replace it. There are several members that part out WD45s and should have a set available. I think the last pair I bought was $40.00 for the pair inclusding the rockshaft.
Welcome aboard, there is an abundance of knowledge and support here on the forum.
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2010 at 7:48pm
O can't answer your first two questions, but I can the third. By lifting a load with a chain rapperd around both arms! or some similiar stupid stunt..........don't ask me how I know.
i have a straight one if you can't get that one straight, yours if you pay the freight, but, you may have to take the whole rock shaft and arms if I don't have the time to seperate
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2010 at 7:49pm
Hey, and that top link bracket is worth towards $100
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2010 at 7:59pm
Yeah Lou, I have said "don't ask" several times. LOL.  There are several salvage yards in this area........will probably just buy a whole rockshaft assembly......shipping makes even free deals impractical these days......thanks for offering........O_O
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2010 at 7:34am
In your picture you have two brackets circled on the righthand side. The top one is one of the brackets for the hand crank. Should be another on on that side that the crank handle fits into.
Wink
I am a Russian Bot
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2010 at 8:25am
It looks like that top link bracket got "tweaked" a little when the lift arm got bent?
You'll definitely have to straighten that 'cause you're not likely to find one of those
at your local farm equipment scrapyard.  LOL
Allis Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Fields Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2010 at 11:36am
They are the same on all wd and wd45's Just get anther set easy to replace.
