will a no 2 cork plug the rockershaft
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Topic: will a no 2 cork plug the rockershaft
    Posted: 22 Apr 2010 at 9:47pm
does anyone know off hand with out going through agco what size the corks need to be to seal the ends of the 226 gas rocker shaft?
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2010 at 6:40am
I buy them at LOWES by the bag full !
Cal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cal Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2010 at 6:50am
I found small frost plugs at NAPA that were just right. I don't like the idea of corks disinegrating in my engine. Cal in Ct.
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2010 at 7:05am
I, like Cal, would try improving on such a primitive thing as a cork rockershaft plug if I was rebuilding a engine.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2010 at 9:58am
I made a new rocker arm shaft for a MF-135. I drilled and tapped for 7/16-20 because the corks rotted out were responsible for wearing out the rocker arm bearings.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2010 at 11:15am
Thanks Fred Lowes had them . I had to buy a new shaft split two old shafts down the seam trying to use a better idea than cork.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2010 at 4:57pm
  takes a number 5 cork from lowes .
