Tore into the ole 45 today
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Topic: Tore into the ole 45 today
    Posted: 22 Apr 2010 at 5:28pm
The rims are shot. The axle seal is leaking. I couldn't take it anymore. Up on stands it went and off came the rims and final drive pans. Is the outer bearing supposed to be a press fit on the axle? When I pulled the axle out, the seal and bearibng came with it? Normal?
NCAllisnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCAllisnut Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2010 at 7:43pm
Yep, the outer axle bearing cone presses on the axle and the cup or race drives into the housing.  Putting it back together and getting the seal into the housing is a trick.
Adam
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2010 at 7:56pm
Well that sounds fun.
Jeff(WD45-SATX-TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WD45-SATX-TN) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2010 at 8:01pm
Is there a shoulder or a stop on the axel? How do you know how far to press on the bearing?
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCAllisnut Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2010 at 8:09pm
If I remember right the seal goes on - probably need a speedy sleeve to cover the groove worn on the axle from the old seal - then the outer bearing cone goes on against a shoulder.  I put the axle in and got it snugged up against the inner bearing, then pried the seal into place by driving chisels between the axle flange and the seal.
Unfortunately I did not take any pictures of this process when I did it a couple of years ago.
Adam
Edited by NCAllisnut - 22 Apr 2010 at 8:12pm
