|  | This site is not affiliated with AGCO Inc., Duluth GA., Allis-Chalmers Co., Milwaukee, WI., or any surviving or related corporate entity. All trademarks remain the property of their respective owners. All information presented herein should be considered the result of an un-moderated public forum with no responsibility for its accuracy or usability assumed by the users and sponsors of this site or any corporate entity. | |||||
| RC |
| Post Reply   |
| ag orange   Bronze Level   Joined: 30 Oct 2015 Location: Media IL Points: 3 |  Post Options  Thanks(0)  Quote  Reply  Topic: RC Posted: 30 Oct 2015 at 12:16pm |
   we installed new rubber wheel seals (got from Steiner ) now wheels drag hard and you here a rubber screeching sound any fix for this Thanks AG Orange | |
| WF owner   Orange Level   Joined: 12 May 2013 Location: Bombay NY Points: 5052 |  Post Options  Thanks(0)  Quote  Reply  Posted: 30 Oct 2015 at 12:30pm |
   Are you sure the noise is from the wheel seals and not the brakes? If it is the wheel seals, it should subside after you drive it a little.
| ag orange   Bronze Level   Joined: 30 Oct 2015 Location: Media IL Points: 3 |  Post Options  Thanks(0)  Quote  Reply  Posted: 30 Oct 2015 at 12:43pm |
   driven it quite a bit  if I pack the back side of seals with grease would that help | |
| WF owner   Orange Level   Joined: 12 May 2013 Location: Bombay NY Points: 5052 |  Post Options  Thanks(0)  Quote  Reply  Posted: 30 Oct 2015 at 2:23pm |
Before I would try that, I would check to see if everything is assembled correctly. Is the problem only on one side? I can't see why you should get any noise from the seals, if they are installed correctly.
| B26240   Orange Level   Joined: 21 Nov 2009 Location: mn Points: 3866 |  Post Options  Thanks(0)  Quote  Reply  Posted: 30 Oct 2015 at 6:27pm |
   If they are dry they will squeak.
| bluewavecaptain   Bronze Level     Joined: 17 Sep 2013 Location: Two Rivers, WI Points: 90 |  Post Options  Thanks(0)  Quote  Reply  Posted: 30 Oct 2015 at 9:10pm |
   Ours squealed for over a year. Give them a bit to wear in.
     Charles(Two Rivers,WI)
| ksbowhunter   Orange Level     Joined: 28 Aug 2014 Location: Newton Ks. Points: 212 |  Post Options  Thanks(0)  Quote  Reply  Posted: 31 Oct 2015 at 4:11am |
   Mine on my WF squeal also just drive it a while they will wear in.
     2-37 WC 37 wf127 37 wf130 | |
| TedBuiskerN.IL.   Orange Level   Joined: 11 Sep 2009 Location: Davis, IL. Points: 1959 |  Post Options  Thanks(0)  Quote  Reply  Posted: 31 Oct 2015 at 8:49am |
   Spray WD40 around the seals and they will stop squealing.
| Lon(MN)   Orange Level   Joined: 11 Sep 2009 Location: Merrill Wi Points: 2040 |  Post Options  Thanks(0)  Quote  Reply  Posted: 01 Nov 2015 at 6:37pm |
   If you put it together wrong it will be noisy. Don't ask how I know this.
| Post Reply   | |
| Tweet |
| Forum Jump | Forum Permissions  You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
