WD's tucked in for the winter
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Topic: WD's tucked in for the winter
    Posted: 20 Oct 2015 at 6:51pm
Folks,
 I was able to just squeeze the two tractors in to the garage. Not much to see of the narrow front end under its blankies. The much newer truck will have to set in the snow.
It was a beautiful fall day in northwest PA, the leaves are near their peak.  Made the  five mile ride on the wide front end from my daughters place to home.
Of course I have a few oil leaks to deal with on this tractor. Oil pressure seemed too low after the run home and only came up when at half throttle?
bigcountry48 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcountry48 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2015 at 8:10pm
They look nice and cozy! That's a good lookin tractor, and I bet the narrow front is too up under the sheets. When was the last time you changed the oil filter? It may be restricting oil flow at low rpms causing low oil pressure until half throttle.
1950 B, 1952 pulling wd, and 1954 wd45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2015 at 8:47pm
Thanks!
Lots of pictures on here of both tractors.
The filter was new a year ago (wow, its been a year already) But the tractor hasn't done much work.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2015 at 10:41pm
It's a by-pass system so a blocked oil filter will raise the pressure not lower it.
Tractors look good in the garage and covered for winter.
I have my newly restored G tucked away the same way, but it's ready to sell.
Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
