7060 shifting problem
bernie wis. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bernie wis. Quote  Post ReplyReply Direct Link To This Post Topic: 7060 shifting problem
    Posted: 21 Apr 2010 at 1:44pm
early 7060 shifting trans or hi lo grinding when you try change gears or try get in gear
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2010 at 1:58pm
Sounds like your clutch brake is out of adjustment or worn out. You have to have the clutch pedal pretty much all the way to the floor, from a fellow 7060 owner.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2010 at 3:04pm
My 7050 was like that but the pedal was hard to push. I could put it to the floor but it was stiff and would grind a little. Replace the cable and all was fine and it pushed much easier.
Wink
I am a Russian Bot
This page was generated in 0.144 seconds.
