Looking for Haban Sickle help...identify this coll
talntedmrgreen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote talntedmrgreen Quote  Post ReplyReply Direct Link To This Post Topic: Looking for Haban Sickle help...identify this coll
    Posted: 13 Oct 2015 at 9:48pm
Snapped this picture of a Haban on the rear of an 620 last year in LaPorte at the GOTO. I now have a Haban 3 pt sickle and am looking for some hwlp gettin it operational. Any chance someone here knows this fella and can redirect me?
Thanks!
Edited by talntedmrgreen - 13 Oct 2015 at 9:48pm
Patterson B1*B1/B1Forklift*B10*BigTen/B1Loader*B110*B208*B206*616*Homelite T16H/T8/T7/RM7E*Landlord/Loader/Trencher*Broadmoor717*Serf525*2110*7790*Legacy XL*Twin 20*Squire9*Squire6*JCPenny 494
Orange4ever View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange4ever Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2015 at 10:09pm
That's my dad, what do you need help with? If you give me the serial # I can get the model number.
If you want a man to be a successful farmer, give him a Allis Chalmers tractor. If you want him to be a successful mechanic, give him a John Deere
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2015 at 6:30am
Wow Josh! Ya hit paydirt man!! LOL!
Post Options Post Options   Thanks (0) Thanks(0)   Quote talntedmrgreen Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2015 at 8:30am
No kiddin! Thanks for the quick response!
I have the manual, actually, but my unit is missing the lift cylinder and cylinder mounts for the bar and the manual does not show that assembly completely. Its a 440 series Haban...same as what is shown on the 620 above but 60" vs 48" and configured for 540 pto vs 2000rpm.
I did learn from the manual that there are alternate pulley configurations to change the speed to suit the tractor. The spline is replacable as well to match the machine running it.
I would love to get some photos beneath the pulley shield to see the lift cylinder setup. Ideally I could get dimensions for it, as well as for the mounting. Then I can work on it this winter to source and fab the cylinder and mounts in time for spring mowing.
I see a few of these when searching, but all are on green tractors, and I remembered this 620 that got me in the hunt for one in the first place!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange4ever Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2015 at 12:39pm
Ours is a 444-D( 4 ft with 2000 rpm), it sounds like yours is a 445-AH which is 5 ft 540 rpm and had factory Hyd lift, the 4' models had a cable lift with option of Hyd lift.
Post Options Post Options   Thanks (0) Thanks(0)   Quote talntedmrgreen Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2015 at 12:45pm
Best as I can make out, mine is a 440-C, which I see as a Deere model with 4' bar. Maybe someone changed some things about mine along the way?
If yours is cable lift then I am more curious....I have a long cable and block pulley connected to the bar, which I assumed worked in unison with the hydraulic cylinder. I am very curious as to how the cable lift is setup, as I may not be missing parts at all!
Post Options Post Options   Thanks (0) Thanks(0)   Quote talntedmrgreen Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2016 at 9:51am
Looking to revive this project....any help would be appreciated!
EricPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricPA Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2016 at 10:23pm
I never knew Haban made a 3 ph model
Life is tough,but it's tougher when you're stupid. - John Wayne
ac720nut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac720nut Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2016 at 6:10am
Hi Tom, not to change the subject but did you ever get the blower and cab mounted on I believe your dad said grandpa's tractor?
This page was generated in 0.234 seconds.
