who's good with math?
alan-nj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan-nj Quote  Post ReplyReply Direct Link To This Post Topic: who's good with math?
    Posted: 11 Oct 2015 at 2:00pm
37 wc with 12.4 x 28 rubber (firestone), 4th gear, 1800 RPM.  How fast am I going?
i know someone knows the ratios and can do the math, I can't.....
went thru radar this afternoon.....faster than i expected,  i want to compare the 2...
thanks
alan
If ignorance is bliss, than happy days are here again.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2015 at 2:04pm
Too little information. What's the gear ratio of the transmission and what's the gear ratio of the differential and what is the final gear ratio at the wheel?
Edited by DougS - 11 Oct 2015 at 2:05pm
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2015 at 2:48pm
About 12.5 mph
But carry a gps with you next time and check it while driving.
Edited by Stan R - 11 Oct 2015 at 2:50pm
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2015 at 3:57pm
The owner's manual should give speeds vs engine speed. The shop manual I have says speed in 4th gear is 9-1/2 mph, but it doesn't show what engine speed that is. It says full load engine speed is 1300 and high idle is 1577 to 1622. 1800 is 1800/1600 times the high idle speed so would put the ground speed up to 9.5 x 9 / 8 = 10.7. 1800 is 1800/1300 times the full load speed and the ground speed would be 9.5 x 18 / 13 = 13.2 mph. The shop manual says the differential gears are 4.7 for standard tires and 6.7 for 36 inch tires. From the transmission cross section it looks like 4th gear is straight through but it doesn't mention the final gear box drive were there is considerable speed reduction.
Working backwards the 12.4-28 tire from Goodyear/Titan handbook has a rolling circumference of 148 inches, which means it turns 428.1 revolutions per mile. At 9.5 mph that's 4067 RPH or 67.78 RPM. The transmission output shaft is turning 1300 RPM, the ring and pinion 4.7:1 puts the axle at 276 RPM and the 67.78 RPM of the wheel puts the drop box gear ratio at 4.08:1.  Close to what I guessed of 4:1 but 4.08 would be better engineering. Its not a great idea to always have an even gear ratio so the same gear teeth mesh each revolution. Gear wear is more even when the ratio is slightly off of an even number.
Again the operator's manual should give speed vs gear and engine speed and the parts book might show the number of gear teeth on the final drop box to show how far my calculation is in error.
Radar can be easily confused by a bigger vehicle behind you giving a stronger echo and the low speed calibration is probably not very precise because it doesn't result in speeding tickets. Then if you are the only moving object the radar shows you slowing as you get close to the radar but off to the side of the radar beam because the relative distance from you to the radar is changing slower than your ground speed.
Gerald J.
Dave in PA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in PA Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2015 at 4:38pm
Grayray, my older sibling is a was, a math teacher years back, good thing for him to do now he is retired! LOL Had to! He will be glad to help if he can!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2015 at 4:43pm
The '37 WC motor was not designed to turn at 1800 RPM. You won't find the speed listed in an owner's manual.
Edited by DougS - 11 Oct 2015 at 4:44pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2015 at 4:47pm
True 1800 is over revving that engine, but there should be a ground speed and engine speed table for slower speeds and then the math is easy, table ground speed times new engine speed divided by table engine speed.
Gerald J.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2015 at 5:20pm
I think all speeds in the book are at 1400 rpm. Need to know the rolling radius of the tire they tested it with.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2015 at 6:10pm
The rolling circumference of the modern 12.4-28 is 148 divided by pi gives a rolling diameter of 47.11" or radius of 23.55 inches. Don't know the rolling circumference of the tire they tested with.There might be ancient tire data in the ISU library if they haven't thrown that history out.
Its easier to use a GPS with ground speed readout to check the speed of the tractor in question. Or get out a stopwatch or a watch with a sweep second hand and a long tape measure. Drive a pre or post measured distance and time that distance, then speed in mph is the distance in feet divided by 5280 times 3600 divided by the time in seconds.  Can be as accurate as you can measure the time and the distance.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2015 at 6:22pm
In other words... steal the Garmin from your wife's car and take the WC for a spin.
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan-nj Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2015 at 6:26pm
thanks.....here's what happened today....township has one of those speed signs that flash your speed when you go past set up on the road by my house.......decided to drive some of the fleet past it and see what happened....its on a bit of a downhill......
---  an RC with 11.2 28 inch rubber, stock gov spring, wide open in 4th read 9 MPH, seems about right.
-- a CA with 24 inch rubber and stock gov, in 4th  hit 12.....pretty close, i think the manual says top speed in 4th is 11.4
-- my 36 WC with 13.6 x 38 inch rubber, with an RC rear end, in 4th gear,  at probably about 1600 or so RPM hit 11-12.  couldn't open it up, front end wobble....
-- the interesting one was the 37 WC... 12.4 x 28, 4th gear.  It has a gov spring from a parts WD45.  Lit up the sign at 15MPH.   I'm guessing at the RPM, my laser meter has a dead battery and I've never checked the RPM's.  Based on the math above, i'm thinking that maybe its a bit more than 1800.  It definitely was the fastest one, by a noticeable difference.  Think I need to put a battery in my meter.  Think I have a new candidate for the club's tractor ride next year.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2015 at 7:40pm
By my math presuming full speed is full load, not fast idle, 15 mph in 4th gear means the engine speed was 1300 x 15 / 9.5 = 2052 RPM probably not healthy for that unbalanced engine.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2015 at 7:49pm
A-C's speed chart was based on 1300 RPM rated engine speed for a WC. So, if it is 9.5 MPH at 1300 RPM it would clock 13.15 MPH at 1800 RPM with the same exact tire diameter.. There is however, a difference in actual tire diameters from a Goodyear to an Armstrong, Firestone, etc......
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2015 at 10:10pm
Not only are there small differences between tire makers, the standards for tire measurement changed drastically between 1937 and 1980 or so. In the old time tire width was the bead spacing, and after that the tire width is the widest part of the tire and the cross sections could be different height too depending on the tire model and manufacturer.
Gerald J.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2015 at 11:25pm
have someone follow you down the road ina car...then ask them!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2015 at 6:35am
Now if the township had a camera in that radar contraption, and reviewed the tape, they'd be sayin' boy, there's an awful lot of Tractor traffic on Pequest Road. Wait a minute!! Its the same guy on all those Tractors!! Who's this knuckehead with all the Tractors wizzin' by? LMAO!! Well, Big Al, its 25 mph in that zone past your house so you still weren't speeding! LOL! The things we do to entertain ourselves... And people bust me about my molecular structure in relation to the ground... sheesh... LMAO!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan-nj Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2015 at 6:38am
so i put a battery in my meter.....the 37 WC is turning wide open at a bit over 2100 RPM...It has a gov spring I took out of a WD45 that I parted out...maybe it wasn't a 45 spring that was in there....
cpg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cpg Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2015 at 7:03am
Approx. 14.6 mph at 2100 rpm. May be different based on tire diameter error but should be close.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2015 at 7:15am
Will need to know tire pressure and your favorite color to be accurate.Pinch
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan-nj Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2015 at 8:08am
stan
i can't quite tell what color it is......
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2015 at 11:20am
Orange then.  That adds 2 mph as the orange ones are always faster.Thumbs Up
1968 one-seventy
1956 F40 Ferguson
This page was generated in 0.516 seconds.
