A-C 175 Lift Cylinder Removal
meta53 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote meta53 Quote  Post ReplyReply Direct Link To This Post Topic: A-C 175 Lift Cylinder Removal
    Posted: 10 Oct 2015 at 5:21pm
Hi everyone.
Well, as I mentioned in my last thread, I got the 175 up and running (remanned injector pump & injectors.) and actually used it for a weekend. That is until I noticed one of the rear lift cylinders had a pretty good leak around the rear seal.  So I got a seal kit, and am trying to remove said cylinder... and finding that to be a problem. The rear was a simple spring clip on the clevis pin. However the front... well the front seems to be a hair pin through the clevis pin?
Also.. The loop of that hair pin is broken off. The pin itself seems to be all sorts of rusted in place. I was wondering what you all would suggest I do to push it out. I was thinking of heating the hell out of it and try to find a punch with that correct dimensions and pound it through?
Is the hole on the bottom of the cast piece (see picture) where the pin would come out? Should I drive it from the top or the bottom?
Thanks again for looking at this post. You guys saved me some serious money with your advice about the injector pump (my labor is a lot cheaper than the local repair shops!)
-matt in CT
NC Bruce View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NC Bruce Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2015 at 5:40pm
Matt
I always drove mine from bottom towards top. Usually had the complete pin to snap in from the top....
Be careful, Don't let it fall on you...
thanx,
Bruce
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2015 at 4:19am
wonder if you could drill it out?
Post Options Post Options   Thanks (0) Thanks(0)   Quote meta53 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2015 at 12:21pm
Well spent a good portion of the day on this. THAT SOB is in there. Like really in the. Even with heat it was a no go. Not to mention from the top down the axle assembly is sort of in the way, and from the bottom the hydraulic return line is in the way.  Yay.
I am just going to drill it out I think.  I need a long metal bit to do so, so looking at Amazon now.
To get the tractor moving, I am probably just going to cap off that line,  and ignore it until spring if drilling doesn't work!
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2015 at 9:13pm
Can you rotate the cylinder pin with a pair of vice grips? That is the first thing. I usually drive a chisel between the inside of the pin and the casting, then take a socket that fits over the pin and tap on the cylinder ears to drive the cylinder in. Don't get too aggressive with the pounding or you can break an ear off the cylinder. If you get the cylinder to slide on the pin, drive the chisel in to force the pin back out. Repeat until you can turn the pin. After you get the pin to turn, you can get a better angle to drive the broken pin out....rotate 180 degrees if needed. You might need to remove the hydraulic lines to get better access.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2015 at 9:43pm
Repair it in the tractor.  MACK
clays37ac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote clays37ac Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2015 at 9:52pm
I had to burn the pins out of my cylinders with a torch. I used Kimball Midwest cool gel spray. To keep the heat away from the rest of the cylinder. After you finish I recommend using anti sieze generously.
Post Options Post Options   Thanks (0) Thanks(0)   Quote meta53 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2015 at 8:56am
Mack, can't repair it in the tractor because their is a clip inside the cylinder holding the ram in, which you can only access through the inlet port, which, you seriously can't get to without removing the cylinder :(
Post Options Post Options   Thanks (0) Thanks(0)   Quote clays37ac Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2015 at 9:00am
Yes the cylinder has to be on the workbench
Post Options Post Options   Thanks (0) Thanks(0)   Quote meta53 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2015 at 11:43am
Well, I can't get it drilled out, because it seems like the hair pin is hardened steel, inside the hardened steel clevis pin. I can't drive it out because it is behaving like it is welded.
Man I am ready to cut the whole business out with an oxy torch and scrap the damn tractor. So frustrated! Perhaps I can burn just the hairpin out?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2015 at 11:55am
Like I said, first get the pin to rotate....then use a long punch to knock out the spring pin....if it is hard, it should break off fairly easy flush to the pin, which helps. If it doesn't want to come out one way, rotate the pin 180 and try the other side. If you want to torch off the bracket, I have a couple laying around here.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote meta53 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2015 at 2:07pm
I need to buy  better punches this evening/week and I will absolutely be doing what you just recommended.
I appreciate all the advice in this thread! :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote meta53 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2017 at 5:02pm
So.
I figured I would check back in and leave some progress notes in case anyone runs into this problem.
1. If you take off the foot rest you will find that the casting that the main pin resides in has a front window, where you can get a much better look at the main pin & hairpin.
2. If you drive a chisel back and forth be very careful not to break off a tab!
    Which, of course I did. I plan on bringing it to my local machinist/fab shop to get a new ear attached.
3. Once you get the cylinder off the retaining ring is easily accessible from the hydraulic inlet port. Use a probe/screwdriver to push ring into the low area next to it. And then you can slide the rod out easily.
4. There are 2 seals, the end wiper seal, and one immediately to the inside of that. On this cylinder the inner seal was crumbly and the cause of the failure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 12:17pm
Disassemble the cylinder in chassis. It does NOT need to be on a bench. It isn't easy, but it's easier than all the grief this one was. Work thru the oil hole after removing the elbow.....been there and dun that many times.
