Allis 7080 overhaul opinions
AllesFarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllesFarm Quote  Post ReplyReply Direct Link To This Post Topic: Allis 7080 overhaul opinions
    Posted: 06 Oct 2015 at 11:43am
So my 7080 developed a knock and turns out a rod bearing went out and it spun it.  ~4500 hours and a black belly.  Just got back an estimate from the shop and looking at just under $8,000 for the overhaul and wondering if it is worth it... bought the tractor less than 100 hours ago for $15,000 and it was a great tractor (while it worked).  Opinions on going through with overhaul or looking into a cummins retrofit or ?
Edited by AllesFarm - 06 Oct 2015 at 12:15pm
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2015 at 12:28pm
New crank for sure and a new viscous crank pulley dampener. Get a different conn rod and check the balance of it to the other five. All new conn rod bolts. Magnaflux conn rods. New pin bushings. Magnaflux the oil pump mounting bracket ears. Set the high idle down to 2600-2650 RPM max.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2015 at 3:18pm
Dam hate to hear that happened with only putting a 100 hours on it as the New owner
Dmpaul89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2015 at 3:55pm
That's a tough call. I think I would go for a used engine. Look on ebay there are a few I think, I saw a NOS long block a couple weeks ago.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2015 at 6:00pm
I definitely would not go for a "good" used engine.  You are taking a complete stranger's word that it is good.  That engine might last 100 hours, just like the original one did.  Get it rebuilt, then you know what you have.
Where else are you going to get a 180 hp tractor for $23,000?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2015 at 8:04pm
Where else are you going to get a 180 hp tractor for $23,000?               Just about anywhere!   And where does it end? Whos to say the rear end doesnt go out after the engine rebuild. Then what. Have 30k in it?
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2015 at 8:11pm
Get her rebuilt and lower the rpms some. Had about the same thing happen on a 8070, put just over a 100 or so hours and blew a piston. 7080's sound so mean they make a Deere wet themselves
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2015 at 8:49pm
I have a Cummins powered 7580 the Cummins is the cherry on the top. I don't know who did the repower but they did a good job. It looks factory. You can find a 505 for $2500 not sure about an adaptor plate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2015 at 9:02pm
Guy sells the plates on ebay I think the kit is about 1200
Jwmac7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jwmac7060 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2015 at 9:06pm
Do not mess with the overhaul...drop a Cummins in it and make a real tractor out of it....we did it with an 8070 and it made it one hell of a tractor. I wouldn't own a 7080, 7580 or an 8070 without a Cummins motor in it. I'm die hard Allis but the 426 was not beefy enough for those tractor's
Dkienzle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dkienzle Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2015 at 9:57pm
If your gonna keep it and use it for a long time I'm in the Cummins conversion camp. We have a Cummins powered 7080 and it is a horse. Very good combination.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllesFarm Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2015 at 9:26am
Thanks for all the advice, everyone.  Appreciate it.  I'll look in to the cummins conversion, that would be with a 8.3L correct?  And if I went through with the conversion how difficult is it- do you basically just need to drop it in and plumb it or is it super complicated?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2015 at 9:32am
It'll cost money to convert. I'd just do what Dr Allis said. Someone said you can get all kinds of 180 hp for $23,000 but you'll have to eat at least $10,000 on your 7080 to get rid of it. With a knock to me it isn't worth one penny more than $5,000. In fact $3,000 would be all I'd pay if you want to sell it to me and deliver it. Economically the overhaul is your best option IMO.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllesFarm Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2015 at 9:43am
Also, here's a picture of the old gal on the baler.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2015 at 10:43am
Too good to throw away
Wink
I am a Russian Bot
TREVMAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TREVMAN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2015 at 10:44am
Picture is worth a thousand words...Look, there is a reason you paid 15k, its a pretty nice tractor for what, 35 years old? If it were me, I'm 49, Id rebuild it and tune the high idle down as recommended. Should last a long time, jmho, Trev.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2015 at 11:51am
I've got a good engine on my 7080, but the pump went out, and I parked it. (there's other reasons why I parked it, not just the pump) been sittin now for 2 years (exhaust covered). if you come here, and take it out, and puts it in yers. I want $2500. for the engine, if it don't run, you don't own it...bring it back for a refund!
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2015 at 12:50pm
Now that there is hard to beat!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2015 at 1:16pm
That would be the route I would take. Buy shameless motor and use the tractor till youve got your moneys worth.    I have a tight farm budget I wouldnt be able to spread your cost of rebuild over my acres comfortably. Your operation may be different so do what you can afford I guess.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllesFarm Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2015 at 1:17pm
Hmm that may be a good option, I'll send you a PM shameless
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2015 at 3:39pm
What do you want for the whole works?
Still in use:
JPG AUSTRALIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2015 at 6:13pm
that's a good deal from shameless,and while your there getting the motor you could get a picture of him
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2015 at 6:26pm
id say that's an awesome deal
7040 engine went bad and found a 70 80 engine for 2500
it was a win win
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2015 at 7:19pm
Orange Blood....I've already offered the engine, wouldn't be fair to sell it all now out from under him....now would it? if he decides not to take the offer then we'll talk! I wanna be fair!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2015 at 7:20pm
JPG....the offer still stands....ever seen a camera smashed all over a driveway? lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2015 at 7:21pm
plus he'll be doing all the work, I can assist with lifting it off the tractor and onto his ride!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2015 at 6:03am
Sorry Dale, I wasn't suggesting you actually sell it out from under him, I was just curious, given the chance he might not take it.  If you have a deal with him, by all means I don't want to get in the way, that's not how I operate.
Still in use:
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2015 at 7:11am
Now I'm confused! Isn't the profile pic you? lol!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2015 at 7:31am
my hair is a little longer Ed!
dpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpower Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2015 at 7:55am
and curly
