hd6b outboard axel bearing
dragboat1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dragboat1 Quote  Post ReplyReply Direct Link To This Post Topic: hd6b outboard axel bearing
    Posted: 05 Oct 2015 at 6:25pm
does any one know the interchange for the outboard bearing on a hd6b .i have linkbelt numbers 19751  3hb94. and race is has 3hb94 .  it looks like a double roller bearing with two seprate races. maybe someone has a good one and some seals. thanks
Edited by dragboat1 - 05 Oct 2015 at 8:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2015 at 10:05pm
it's a link-belt bearing and is not interchangeable with anything - a spherical roller bearing rather that tapered like timkins or straight rollers .
 Might try gemdozer View Drop Down on here to see if he has any or access to
donoman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote donoman Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2015 at 12:43am
that bearing is no longer availible there is one ,I don't have the number handy but you need to machine the output bearing housing to fit it , it is a common size
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2015 at 7:41am
The bearing on my HD6G is link belt 3HB94-0
As stated the 50mm x 100mm x 42mm bearing does not interchange with anything. 50mm ID spherical roller bearings have 90mm or 110 mm OD's
The closest bearing I found was SKF 22310CC/W33 50mmx110mmx40mm. You will have to bore your housing. This bearing is not as wide as the original.
On eBay NOW for $116.81 SKF 22310-E
2 indicates spherical
next 2 indicates width 40mm
3 indicates diameter 110mm
10 indicates bore 50mm
Do not purchase a bearing with -K
Post Options Post Options   Thanks (0) Thanks(0)   Quote dragboat1 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2015 at 9:23pm
thanks for the input everyone. that is the same # as mine. this is what ill have to do,thanks again for your time and effort.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2015 at 12:30pm
HI  I should have a used bearing and a new boot seal and ring seals
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2015 at 4:57pm
have you tried Rexco company 515-287-4910 They used to have all kinds of older Link Belt parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dragboat1 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2015 at 4:33pm
MR gmdozer how much for the bearing and seals where i can tell the owner. would you have a extra nut my axel is 6 spline. what are the mesurements of the hex of the nut . we had one made not sure if it is wright size. and how would i get yor money. thanks alot.
This page was generated in 0.172 seconds.
