hd 6 b 6spline |
dragboat1
Topic: hd 6 b 6splinePosted: 05 Oct 2015 at 7:43am |
does anyone have a photo of the sprocket and nut separately . also does sprocket fit tight on axel mine I can slide on by hand. thank for your tme
Edited by dragboat1 - 05 Oct 2015 at 7:54am |
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 05 Oct 2015 at 7:59am |
sprocket should slide on by hand until it seats on the tapered splines
Dad- WD, D17D, D19D, RT100A, 7020, 7080,7580, 2-8550's, 2-S77, HD15 |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42268 |
Posted: 05 Oct 2015 at 9:24am |
once axle is onto spline the nut drives it home onto the taper - it should not be loose or wobble when placed by hand and then then should feel snug
dadsdozerhd5b
Joined: 27 Sep 2009 Location: lansdale pa. Points: 537 |
Posted: 06 Oct 2015 at 7:39pm |
![]() hopefully this pic of the axle went through. not sure what else you may need |
dadsdozerhd5b
Posted: 06 Oct 2015 at 7:43pm |
![]() hub pic |
Ian Beale
Joined: 03 Oct 2011 Location: New South Wales Points: 1009 |
Posted: 07 Oct 2015 at 4:28am |
dadsdozerhd5b
Have a look backwards from here for what Killdozer is proposing for a wrecked sprocket spline - if you're near a GOOD machine shop I'd say! http://www.redpowermagazine.com/forums/topic/83591-1952-atc-terratrac-gt30-track-loader-roller-repair/page-22 |
CAL(KS)
Posted: 07 Oct 2015 at 8:57am |
wow.. looking back, definitely a labor of love Edited by CAL(KS) - 07 Oct 2015 at 11:05am |
