HD5B Filters
Bata93 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bata93 Quote  Post ReplyReply Direct Link To This Post Topic: HD5B Filters
    Posted: 04 Oct 2015 at 3:55pm
Wondering if anyone knows where you can buy fuel filters and oil filter for the HD5B with 271 detriot? Where has anyone had the best luck in cross referencing part numbers? Any help much appreicated Thanks
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2015 at 5:54pm
NAPA AUTO PARTS, THE FUEL AND OIL FILTERS ARE BOTH 1010 AND I USE A HOME FUEL OIL FILTER FOR THE PRIMARY FUEL FILTER
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2015 at 9:11pm
for the primary fuel filter I have a 10 micron water filter of the spun poly material - I cut the 10" filter down to get 2 fuel filters from it - the same filter is also used on Trane Centervac compressors used for industrial cooling systems - its a oil filter for them .
 I was using a oil filter for a 52 Plymouth 6 cyl engine as it could be found back in the 70' and 80's - Now I use spin on filters PH8A on a bracket I made up
Edited by Coke-in-MN - 04 Oct 2015 at 9:15pm
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2015 at 9:23pm
For some reason unknown to me, people try to improve there HD5 and add other filters.Since I am the same age as a HD5 and not around one until my teen years maybe there was a reason to change,but I think the original where Fram canister drop ins same as Ford N series tractors and lots of other stuff. So if they are canister type and hold a quart they are original. C P 1 comes to mind as the old fram number but my rememberer is more like a leaky tank any more.
Mechanic insisted I put spin on filters back in the 83 when engine was over hauled.The bases ended up Ford standard of the time. He had a problem over tightening the top of fuel filter,and it needing a new gasket. But what was done is neat compared to some.
Funny how thinks kinda go in circles as I understand new cars are back to canister filters so you don't pitcher as much metal in the garbage to change filter as a spin on .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2015 at 9:29am
the original filters were AC filters as marked on top of cans - but they became hard to find and I searched for one that was about the same size which was the Fram C 3 - I added a washer on top and bottom to help support and hold filter onto rod .
 Reason now for the backwards move is the cartridge is easy to crush - extracting any materials that do not meet guidelines for disposal in landfills or burning without special capture ..
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2015 at 12:34pm
Wix has them all. HD3, HD5, HD6.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bata93 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2015 at 7:37pm
Thank all of you for the information, it is a tractor i just purchased within the last year, much appreciated
