720 seat is too low?
Herb(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Herb(GA) Quote  Post ReplyReply Direct Link To This Post Topic: 720 seat is too low?
    Posted: 04 Oct 2015 at 12:17pm
If the seat on our recently acquired 720 was several inches higher my opinion is dismounting would be easier and operator's vision may be improved.  Nothing in that area appears to have been modified (lowered).  At first glance such change appears to be readily doable; sorta like 'too good to be true'.
Would appreciate suggestions, and especially anyone's knowledge of experience on this subject. Herb(GA)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2015 at 7:43pm
Herb,
The only thing I could think of to raise the seat is put a spacer bar (like a piece of square tubing) under the seat front and rear where it bolts to the transmission. I just installed my new seat on my 620, and there's only 4 bolts that hold it to the tranny. The bolt holes in the seat frame are slotted a little bit to.  HTH
Steve@B&B
This page was generated in 0.271 seconds.
