7000 serial number 8213 clutch springs
Clay Bragg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Bragg Quote  Post ReplyReply Direct Link To This Post Topic: 7000 serial number 8213 clutch springs
    Posted: 19 Apr 2010 at 7:03pm
i have a late model 7000 powershift.looking for an inching spring (very heavy spring under rear of cab about 6 inches long) also spring that holds linkage together not pedal return spring.agco parts website does not show these .part numbers would be helpfull.thanks 248 431 0711
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2010 at 8:47pm
That sounds like the transmission brake spring....left side in behind the fuel tank and just underneath the cab floor????
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Bragg Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2010 at 5:37pm
that is correct .agco has no part number for this
pfctyler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pfctyler Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2010 at 6:07pm
I just searched the Allis 7000 parks book in Epsilion and I didnt see what you are talking about either.  I have a couple old Allis 7000's that we have parted out that maybe have what you are after.  Trouble is that it will be a couple weeks before I can get to the tractors.  If you still need one send me a PM and I can see if I have one.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2010 at 9:42pm
 I checked AGCO parts on line and I believe that everything is shown.Late model 7000 is a little different design,and even some of them were updated when new.Part #70271971 is the spring.There is also a kit that may be required depending on tractor serial number. Kit part # 70271977.These parts are shown in the drive train section under engine clutch controls.
