Mower deck spindle
JohnCinMd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCinMd Quote  Post ReplyReply Direct Link To This Post Topic: Mower deck spindle
    Posted: 19 Apr 2010 at 6:43pm
I need the center spindle & double pulley that goes on it for the 48 inch mower deck thats on the AC 917 garden tractor. I believe the Simplicity deck is the same. Anyone got one they're parting out? Thanks.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2010 at 7:11pm
I will check my stash of spindles for you, just mounted that same deck yesterday. Chris/CT
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCinMd Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2010 at 9:09pm
Thanks Chris!
Cal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cal Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2010 at 9:16pm
John  There are different height double pulley assy's you will need the mower model # such as 169xxxx to get the correct parts, or you might get lucky guessing. We should have the parts new if you can't find used. Cal in Ct. @
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCinMd Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2010 at 7:40am
Cal, the deck is a replacement that has been put on the tractor after the original rusted out. I think it's a Simplicity & not AC. Is the number stamped somewhere? There's no number plate anywhere.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2010 at 7:59am
John, Didn't realize it was not original. I have a dozen different center spindles here, some new/some good used, maybe e-mail me some dimensions off yours, send me picture of deck and spindle assuming you have it out on bench.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCinMd Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2010 at 12:02pm
Sorry Chris, I was thinking the Simplicity & AC were interchangable.  I'll take some pics & post them.
otis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote otis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2010 at 5:40pm
have a 616 tractor,60in. deck,and a front hyd blade.want to sell all.rough shape.runs,hydrastat good.mowed with it till sons truck burnt and tires got too hot.sitting next to truck.500 for all.
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2010 at 11:37pm
The decks also came with a MFR# tag on them. If you're lucky it will still be on there and you can use it to lookup parts.  Manuals can be had at www.simplicitymfg.com by going to the manuals tab.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCinMd Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2010 at 8:49am
Here are some pics of the pulley & spindle. The splines are really worn down on both, so I need the whole assembly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2010 at 11:00am
JohnC, can you post a picture of the deck also?
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCinMd Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2010 at 4:32pm
Here ya go Chris....
I can't find any identifying labels anywhere, just the 2 caution stickers.
Cal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cal Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2010 at 7:11pm
John It looks like the original deck rusted out and a new housing was installed using the original components from the 917  mower. What you have is the later housing with your early parts, thats why the cast spacers on the under side, those came with the replacement housing kit to get the blade at the right height. ThaT IS WHY  you don't have a model sticker on the deck, it was on the original housing and not trans fered to the new housing. I will look up the part  #s you need and get back to you. Cal in Ct.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2010 at 8:41pm
Learned something new there, just last month scrapped a rusty deck like that with spindles that I think were OK. I was too lazy to deal with it!, Shell was gone. I've been fighting decks here last week or so, I iunderstand now why I canned it. I do not have that type spindle, may have some NOS shafts for the spindles in basement.
Cal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cal Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2010 at 9:06pm
John Thenew parts that I am listing are figuring that you will use your old upper & lower housing. Center shaft with bearings installed $60.  dbl pully assy. $60. top capscrew$1.50   Lockwasher $1.50 ,thick washer $1.50 ,upper brg. shield$3.20. I don't know if you need the blade side parts but here they are. Shim washer (against brg. ) $1.60, grass shield $2.65, blade hub $9.55. I hope that this helps you. The model mower that I looked these up for is 1690502 that was the 48" mowerfor a 917 from 1979-1986. We do have these parts in stock, of course the shipping would be extra. Cal in Ct at Yankee Sales & Service
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCinMd Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2010 at 11:23am
That's ok Chris, no problem.
Cal, I might call you. I want to check out some sources around here first.
Thanks guys,
John
