8010 trans/ rearend oil dipstick
ac45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45 Quote  Post ReplyReply Direct Link To This Post Topic: 8010 trans/ rearend oil dipstick
    Posted: 19 Apr 2010 at 9:31am
On my newly acquired 8010 the dipstick for the rearend is missing, alm0st like it has broken off, The cap etc is  the same and original. This is on a powershift tractor. IS this the same as what would be on my 7060 PD as far as fluid level, Can i just use the 7060 dip stick to check it?  Is it ok to use universal fluid in this rearend/ transmission??
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2010 at 10:53am
No dipstick,I think you will find sight bulbs down on left side.
rieg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rieg Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2010 at 11:29am
There should be a dip stick for the power shift above and to the left of the rear end fill port. the levels are different for FWA it will be marked on the stick.
rieg
