Gleaner M2 air conditioning problem
Sandknob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner M2 air conditioning problem
    Posted: 24 Sep 2015 at 7:52pm
My M2's A/C is not working and I tracked it down to the pressure sensor closest to the grain bin. I have power to one side of it, but not the other wire (the one that goes to the compressor). Can I bypass the sensor to get it working? If not, can I take it off to replace without losing freon?
Thanks
Adam
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2015 at 9:46pm
yes it unscrews and no loss will occur - unless it has been messed with. That would be either a low or high pressure switch to shut down the compressor if the psi drops below about 5 or above 400 approx. better put a set of gauges in to check
