WD45 manifold question?? |
Post Reply ![]() |
Spelt Farmer ![]() Bronze Level ![]() ![]() Joined: 10 Jun 2013 Location: Ohio Points: 91 |
![]() ![]() ![]() ![]() ![]() Posted: 23 Sep 2015 at 3:14pm |
Our WD45 blew an exhaust gasket. I got things are apart and mostly cleaned up. The manifold is a bit rough. Considering the price of new manifolds I planned on taking it to the local engine shop to have it faced off on their sander.
Out of curiosity I decided to check it for warp, and noticed the #1 and #4 exhaust ports are about 1/16" higher than the four center ports. Every other manifold I've dealt with had everything in the same plane. So, is there supposed to be a difference? If so, what is the exact amount? ![]() -Aaron |
DaveKamp ![]() Orange Level Access ![]() ![]() Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6081 |
Double-check the mating surface, and see if it's actually flat. IF it's flat, then you're seeing core-shift... a flaw that occurs in casting when the plugs in the mold (that create the core) don't stay in position during the pour.
IF the surface isn't flat, then what you're seeing, is enough erosion on the end ports so that the 'ramp' of the port has a higher apparent position. It is not unusual for these engines to exhibit erosion around the #1 and #4 cylinders- Thermal expansion causes the manifold to lose contact pressure against the gaskets on those ends, and when that happens, hot exhaust gases leak around the gasket, burning away the iron castings on head and manifold. Eventually, the iron 'burns' away, and the result, is that the port's apparent position and opening shape becomes distorted because of the missing metal. Another issue that exacerbates the condition, is that the hardware corrodes away. If there's a washer with a nut holding a casting, and the washer rusts away, the tension goes away, and now there's no gasket pressure. I had a particularly eroded cylinder head on a WD, but the rest of the head was in stellar condition, so I put the head in a vertical mill, and elevated the #1 end about 0.100" higher than the #4 end, then started planing off the manifold mounting surface until I got something that was reasonably flat... then I put a new manifold and hardware on. The end result, of course, was a manifold that if you looked really, really close, appeared to stick out of the #4 area more than the #1, and it did... but I had a flat, and secure seal that's been good ever since. With these engines' performance envelope, the little change of port volume or geometry has no substantial effect on running character. |
So in theory the manifold mating surfaces should all be on the same plane? And the exhaust gaskets are all of equal thickness?
That's the theory. In real life, the engine is a thermal device, so when it warms up, things distort and deflect.
Although these engines seem to be simplistic in nature, the industrial engineering that went into their manufacture was brilliant. If you examine each part, you'll see that the machining operations for every piece are actually very minimal, and there are very few planes which rely on other planes in order to get proper fitment. Here's an example: In a typical V8 engine, the intake manifold spans from one bank of cylinders to the other, and also covers the pushrods and lifter valley. In order to properly seal against both cylinder heads AND close the valley, not only does the cylinder head port face need to be precisely angled and flat, the cylinder head needs also to be flat, and at proper angle to compliment the port face. Next, the manifold needs to have a flat plane, with proper angle matched across the top of the lifter valley AND the opposite bank. There's lots of complicated tooling required to make that happen. Next, look at a cylinder head. In order for the engine to be balanced in operation on each cylinder, each combustion chamber needs to have the same shape, and proper valve alignment. That means the casting process needs to be perfect. Compare that to how Allis did it: the manifold bolts to a flat plane, and there's NO other dependancies. The cylinder head is totally flat, with holes cut in it for valves. Notice... the combustion chamber is (if you have Power Crater pistons) HEMISPHERICAL... that hemisphere is made on a lathe, with a radiusing attachment... so they're all essentially perfect. Couple that to a flat cylinder head surface, you've got an inverted hemi. Oh, and the valves... no fancy angles... once the head surface was cut flat, the machines drilled the holes perpendicular to that plane, and it was done. Henry Ford didn't hold a candle to these guys... In my opinion, it's the epitome of simple, yet brutally effective engineering economics... |
Brian G. NY ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: 12194 Points: 2269 |
The D-17 I bought would not fire on all cylinders.
I discovered that the manifold was somewhat warped even though the prior owner had installed a very nice looking used manifold with all new gaskets. I simply used a very large file and lots of elbow grease to assure all the port surfaces were on the same plane and I no longer had a problem. A milling machine would have done the job much quicker and easier.
Sounds like it's time to get out the torch, and do some brazing.
Any hints on how to fixture the manifold in a milling machine? -Aaron
DougS ![]() Orange Level ![]() ![]() Joined: 03 Nov 2011 Location: Iowa Points: 2490 |
You might want to consider propping it up on a surface grinder if you plan on planing the mating surfaces.
It's been a few years since I skimmed a manifold, but I think I just used the mounting bolt holes, and put strips of metal between the manifold and mill table, and bolted it down. The iron wasn't hard, so it skimmed off easily. I have a 4" diameter Carboloy face mill, and I believe it may have been wide enough to do the whole thing in two overlapping passes.
Doug's suggestion of surface grinding works well, too. A guy could do it with a belt sander and a pair of sawhorses... the fact that there's no other dependant planes, makes it darned near impossible to screw up. ![]() |
On a side note, the original failure was due to corrosion of the manifold studs. It looks like the threads pretty well rotted away, thus allowing the tension to relax on the manifold. After looking online, and calling the local dealer, I opted to buy the studs from McMaster-Carr. They're 18-8 stainless, so should outlive me. They're 5" instead of 4½", the 4½" stainless had an excessively long thread on both ends. The studs from McMaster were considerably cheaper than AGCO, and they arrived the next morning by UPS.
![]() ![]() This afternoon I commenced to working on the manifold. The faces were ground back for get rid of the pits, then brazed up. It took a good bit of tinkering around to get it set up in the milling machine. Milling proved that I need to add some more metal ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks for looking -Aaron |
Beware of stainless. It can gall and seize like no other material. Use plenty of anti-seize goop.
That's the truth, although not as badly as titanium. |
Avoid titanium in there, too... it's so pricey that the Allis won't know how to run right.
The only concern I have with stainless studs, is that they're typically softer than plain steel, hence, they'll strain under the manifold's thermal expansion, and stretch. Allis probably didn't worry much about it back then, but my choice nowdays would be something that's rather elastic. Keep a close eye on 'em, and don't be surprised if you get harrassed by the 'correct police'. ;-) BTW... Nice brass! ![]() You could've just kept mowing 'till you got to good iron. I think I've chewed over a quarter inch off one of mine, and it worked out fine. Edited by DaveKamp - 25 Sep 2015 at 8:44pm |
TimCNY ![]() Orange Level ![]() Joined: 15 Apr 2014 Location: Upstate NY Points: 1551 |
So after all this, the price of a new manifold still seems high?
Sometimes, it's not about the destination, it's about what happens on the way.
![]() Or if he's like me, the milling machine needs a little exercise, and there's three other projects in the shop goin' at the same time, so it's a no-expense task. Why do we work on these old tractors anyway... We could just throw the whole lot of 'em away and get new ones... ![]() |
It just rubs me the wrong way to pay $180 for a Chinese manifold. If I have 10 hours in it, that's $18/hr.
Ultimately it's for the challenge of it, and building skills. If one is going to learn manifold repair, it's better to start one that is replaceable, not an some rare antiquity. |
HD6GTOM ![]() Orange Level ![]() ![]() Joined: 30 Nov 2009 Location: MADISON CO IA Points: 6627 |
I echo the fact about the stainless steel studs-be very careful with them. The farm coop I was associated with years ago used stainless in the fertilizer business, not because they came apart easily after 10 years but because they twisted off easily after all those years and the boys found things quicker and easier to fix than when using mild steel bolts.
It'll be interesting to see how they work out long term. The original AC setup used brass nuts, so the torque range should be okay.
In another departure from the original setup, I bought some stainless Belleville washers to use between the nuts and the manifold. My thinking is that they'll help keep things snug. Someone has to reinvent the wheel ![]() I work in a salt factory, so I'm somewhat familiar with nonferrous fasteners, everything there is stainless, bronze, or Monel. I'm not keen to remove any more than I have to from the manifold, as there doesn't seem to be much clearance between the carb and the block. Edited by Spelt Farmer - 26 Sep 2015 at 11:25am |
I'd at least use brass nuts on the stainless studs. There's no getting a seized stainless nut off a stainless stud. Been there, tried to do it. Stainless has its virtues, but it is not tolerant of acids. It should work here.
For now it has steel nuts, I thought I had some bronze ones but cannot locate them.
Reassembly included some use of red silicone sealant. While the mill was plugging along cutting the manifold I took time to check the head. The #1 and #4 areas of the head are eroded a solid .025", so even with the corrected manifold the gaskets are going to have a tough time. The tractor is due for an overhaul, and restoration, so we'll mill the head then. Are the Vinson manifolds that much better, presuming one can be found? -Aaron Edited by Spelt Farmer - 26 Sep 2015 at 2:34pm |
Wendell(OK/TX) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Stratford, OK Points: 552 |
Been over 10 years ago but I bought a parts wd that wound up being a runner with the manifold leaking. Took the mainfold to a local small engine shop and he smoothed it up on a flatbed grinder, over an 1/8 inch of material taken off in some places to get in all in the same plane. About $30 if I remember correctly. At the time, Mcmaster-Carr had the steel studs and brass nuts so I went with that option, all worked great till a bearing shelled in the rear diff and I haven't gotten back to it.
Any comments I have, would not be from actually comparing the two parts, because I've never seen a Vinson, but I will say that the quality of the casting, finish work, and iron in the imported manifolds I've bought and handled, were not worthy of deep fulfilling pride. The scrap material going into the furnaces of our asian sources is far from 'clean'. That being said, I have three such manifolds, and after cleaning them up myself, they work fine. I second the motion on using brass nuts on stainless. I've never had the pleasure of going SCUBA diving for the mere experience, but the several times I've worn a tank, mask, and mouthpiece, I was holding a hacksaw and sawing off the stainless nut that some bozo installed on a $5000 stainless propeller shaft... ![]() |
The last manifold I had done ended up being so far out of square that the muffler wouldn't fit through the hood. Expect it depends on whom is operating the grinder ![]() For the curious, here's how I ended up setting it for machining. ![]() All installed, plus my homemade exhaust pipe bracket. After reading many of the discussions on mufflers, and doing some price checks, I opted to go with a stainless straight pipe. Used a bit of the 'red kind' to seal it up tight. Thus far it doesn't seem offensively loud. ![]() Fortunately the Correctness Police have no jurisdiction in this township. The hood got a quick coat of primer in hopes of staving off the rust for a bit. The manifold got a quick shot of manifold paint, which from previous experience should last until the next rain. The exhaust pipe is a bit long, but the post driver usually clears the way. ![]() Now, once I get the generator issue figured out.... -Aaron |
Ouch! Going to bark without a muffler. I lost my high end hearing in my left ear 20 years ago. Too much time on a tractor with that ear turned toward the exhaust.
Yeah, it'll bark a bit. I think I'd be more concerned about keeping rain out... need to put a stick on the can so's you can reach that high... ;-)
Post Reply ![]() |
