Ever brought home a parts tractor
ToddSin NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddSin NY Quote  Post ReplyReply Direct Link To This Post Topic: Ever brought home a parts tractor
    Posted: 18 Apr 2010 at 7:44pm
Then couldn't part it out? Bought a WD 3-4 months ago with the idea of parting it out. I have been looking at it for 2 months and just can't bring myself to parting it out now. Anyone else have this problem?
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2010 at 7:46pm
Call Norm!!!!
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2010 at 7:47pm
I have 3 or 4 that would probably qualify as parts tractors, but they all run and could be decent tractors with a little rubbin'. I haven't had the heart to take one apart yet.
KevinC(MD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinC(MD) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2010 at 7:48pm
Most definitely...have the same problem with a 43' B out back.  Bought it to use for parts and now it is heading for the light pulling classes.  Instead of making money, it's costing me big!  That's ok, at least it's gonna keep running instead of rusting into a heap!
wf32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wf32 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2010 at 8:22pm
Yes same thing happened several times  but WDs are worth more in parts than can  sell as a running none restored WD for
Phil
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2010 at 8:22pm
Yep, got a 51 WD out in the shed that needs an engine. After getting it home I realized the draw bar hole is still round, the hand clutch and brake pedals still fit good without wobble.
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2010 at 8:37pm
My first WD 'NF' with a stuck engine was free. I towed it home 10 miles at 5 mph because the front end was so sloppy I thought it would flip over going any faster.
The battery box and dash panel was full of yellow jackets I found out after the first big pothole. It was a long ride.
Fixed it up on the cheap and used it for 4 years and sold it for $1200.
It was worn but a very usable and dependable old tractor.
Never let me down a single time.
That is what got me started on AC tractors
bigfish_Oh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2010 at 8:44pm
my WC was parts till it started !
my second 45 was good till I had to recover some investment and part it out, the previous owner should not have put so much in such a pitted frame.
1941 WC sat for 29 years,started & dynoed 27 h.p.
1957 WD45 Grandpa bought new,factory p.s.,added wfe
1951 WD, factory p.s.
1960 D14 HnMk IV BkHoe 4 sale
2014 HD Tri Glide
2009 GMC CC SLT Dually
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2010 at 8:45pm
Bought a sorry D12 with a stuck engine and mostly complete. Got the engine freed up and it ran real good. However, some of the tin and tires were not good, and the hitch was gone....so I purchased a "parts" D12 anf with some of its parts and tires/hitch from a parts CA got it together. Ran out real nice, so cleaned it up and painted it. Now, it looks and runs out great. Then....I decided the "parts" D12 could be salvaged. It is now running good and I have used it this spring plowing with a 2X14 SC plow. I had to scavange parts from the CA (and others), fabbed up a lot of other items to replace the parts robbed for the other D12. Need fenders for it; tho I think I can make use of some D14 fenders to get it together.
Bottom line, I could have purchased a real decent restored D12 (and a ???) for what I have into the 2 I have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2010 at 8:48pm
but anyone can buy a decent tractor
for what I have in any of mine, I could have have bought a nice pretty one, but that would be as much fun as falling off a log.  If you're tying to sell me a pretty one not needing anything, you better sharpen your pencil.
Edited by bigfish_Oh - 18 Apr 2010 at 8:52pm
2014 HD Tri Glide
Clay in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay in MI Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2010 at 8:49pm
Parts tractors were the only ones I could still sneak by my wife.  I'm not sure what I'll try now that she has caught on that  "parts tractor" means it will be needing parts in the future.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2010 at 8:59pm
Sometimes the next parts tractor is all you need to resurect the other one,  maybe an engine, trans or something. Just don't know where some of these projects are headed till later.
kip in cny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kip in cny Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2010 at 9:41pm
its not that bad that WD you can save it so your 45 has someone to play with
160 CA 920diesel 5020 HD-3
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2010 at 10:25pm
My '45 WC was bought as a parts tractor at a farm sale but after getting it home and finding out it ran, it was put back to work on the place. that was about 6 years ago and it's still in one piece and working. (Could use brakes, though!!)
woodbutch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote woodbutch Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2010 at 10:16pm
The guy I worked for when I was in high school had a johndeere 55 combine that sat in the weed row forever. Well the neighbor offered him  $500 for it for a parts machine . Two weeks later it was their main combine. I would guess that was a cheap harvest.
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2010 at 10:26pm
"Anyone else have this problem".............uh, I wasn't aware this was a problem! If that's the case, I've had this problem 'bout six times now! and as far as making money, I've given more stuff away than I've sold.
Edited by LouSWPA - 19 Apr 2010 at 10:30pm
Nick in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick in MI Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2010 at 11:12pm
We have that problem once in a while but then we realize that the only way we can fit them in the barns is if they are on the shelves lol
Ashes to ashes, dust to dust, if it weren't for John Deeres our tools would rust
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2010 at 5:04am
Nick, So that is what my problem is. I have two setting outside now and down here, that is not a good thing.  LOL God Bless.
Hudsonator View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hudsonator Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2010 at 9:22am
All of our tractors were "parts" tractors when we bought them.
Of course, we have an obscene amount of time and money in them, but they have done an obscene amount of work for us as well.
There isn't much a WC can't do.
WD's just do it better.
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2010 at 10:52am
Yep, a number of times.  I know it makes more business sense to drop 'em, but I just can't do it everytime.  That's why I love a thrown rod, or something major.    No decisions to make, just start wrenching.
My D15 II was a very early purchase for the company.  I towed the carcass on the trailer, but had more parts in the back of my suburban than on the trailer.
Use it daily now.
