Leaking Sediment bowl-help??
Mark in Iowa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark in Iowa Quote  Post ReplyReply Direct Link To This Post Topic: Leaking Sediment bowl-help??
    Posted: 18 Apr 2010 at 7:22pm
Suggestions for stopping a leaking sediment bowl on my old Frazer tiller? I put in a brand new cork gasket. Bowl is on straight, still drips quite a bit.
                             Thanks
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2010 at 7:37pm
  wrong bowl or use 2 gaskets  might be cracked when tightened
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2010 at 7:38pm
  top could be bent from overtightening also
Dave A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2010 at 7:42pm
check the bail. some times the threads feal tight but the bowl is still loose. Dose it stop leaking when you turn the fuel off. Hove seen a lot of them crack just before they go into the tank. and then run down the bowl
Play the game for more than you can afford to lose... only then will you learn the game.
Winston Churchill
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2010 at 8:04pm
One of mine had a warped top as Norm noted......leaked a LOT and there was no fixing it. Replaced that top and all was fine.
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2010 at 8:18pm
There is a way to fix it other than buying a new one. I had one that was bent from over tightening and it leak bad. I took it off the tractor and chucked it up in my lathe and faced off the bottom of the casting where the bowl seals. It worked great. If your time is worth anything it's still probably cheaper to buy new. Charlie
NICKMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NICKMI Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2010 at 8:54pm
ive got a d 17 with the same problem I just put a  regular 5 cent nickel under the bowl tightend it up and problem was solved good luck
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2010 at 7:27am
As you tighten the bale give the bowl a twist, it helps seat the bowl.
Dusty
This page was generated in 0.045 seconds.
