hyd leak
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Topic: hyd leak
    Posted: 21 Sep 2015 at 8:44pm
anyone know the easiest way to take a hyd cyl out of the inside arm of an extend-a-hoe? have a leak in there somewhere, dunno if it's a line or a seal...buts it's really pumping oil out! I put a pin in it to hold it up inside, but it's still pumping oil out...must be a line!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2015 at 11:35pm
if its leaking and you have the valve also in neutral should not leak unless valve body is leaking also .
 there is a pin on cylinder rod that goes into inside slide - remove that and other pin at end of cylinder and it should come out of arm .
 Hoses should be visible  on top of cylinder -
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2015 at 10:56am
thanks Coke
This page was generated in 0.250 seconds.
