This is my oil filter??
Tractornewb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tractornewb Quote  Post ReplyReply Direct Link To This Post Topic: This is my oil filter??
    Posted: 21 Sep 2015 at 4:50pm
Defintaly not a pha8 application Napa said part number came back as a hydraulic filter. I removed it from the top right it sits upside down
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2015 at 5:15pm
Wouldn't the NAPA # be 1101 for the oil filter used for that tractor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2015 at 5:16pm
Looks like a Fram c159.   What tractor?   Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2015 at 5:17pm
Might even be the 51101 or Fram is C159.  Rick
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2015 at 5:18pm
B/IB/C/CA/WC/WF/WD/WD45/RC/early D17's for sure.  Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tractornewb Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2015 at 5:18pm
D15
MrHDC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrHDC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2015 at 5:24pm
It looks like a NAPA 7011. The Fram replacement # is C 159.
Hervey
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2015 at 5:37pm
Early D15, not a series II.  Later used the pH8a equivilant.  Early used the ones with jar threads and the center stand pipe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrHDC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2015 at 5:38pm
OK - I'm hesitant to say too much about filters 'cause its kinda a touchy subject on here. I believe the NAPA 7011 replaced the 1101 model. I recently rebuilt my CA engine and had good oil pressure with both the 7011 and the C 159. I can't say for sure it's the same filter you need on your D15 but it looks like it.
Hervey
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2015 at 5:41pm
The 7011 probably is the new number, I couldn't think of that number, but I know the 1101 is the older number.  Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2015 at 6:04pm
newbe........... everyone is right. The ALLIS tractors in the 1940-50s used the filter you have above in the photo. It is a bypass filter, stuffed with cotton and filters about 15% of the total oil flow.  The FRAM number s C159............ The PH8 filter was used sometime after 1960 on the newer D series tractors ( not the very first ones) and it has the spin on center tube like used on all autos.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2015 at 6:30pm
ALL D-15 gassers used PH-8A style oil filters. D-14's did not. If you find a D-15 that has the old cotton string filter, someone put a D-14 engine in it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tractornewb Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2015 at 6:33pm
Someone must have swapped my engine!
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2015 at 6:39pm
If you get the motor number from the side of the block and post it here that will probably help to figure out what you have
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2015 at 7:42pm
We had a D15 3pt hitch that we blew two holes in the block (connecting rod let loose and punched a hole on each side) and we put a D14 motor in it. Sold it 35 years ago. Just wonderin if it is our old one??? MA and NH are border states......
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tractornewb Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2015 at 7:50pm
Wow that would be crazy you tell me?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2015 at 7:55pm
Nope, different seat style, different loader, black grill (we had white), from what i can recall. Nice tractor though.
Edited by Stan R - 21 Sep 2015 at 7:56pm
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2015 at 8:32pm
I have to agree with Dr Allis on this one. I have an early D15 and it has the newer type filter, not the one shown. However my D14 does use the one shown. LOL Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tractornewb Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2015 at 4:42pm
Tractor is running AWWSOME !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2015 at 7:26pm
That is good to hear. Bet you are glad you didn't loose hope and sell it.
