Looking for horsepower
48ACWD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 48ACWD Quote  Post ReplyReply Direct Link To This Post Topic: Looking for horsepower
    Posted: 17 Sep 2015 at 8:35pm
I'm looking to get serious horsepower out of a wd 201 engine and don't have a clue where to start. Trying to out pull the JD guys will be no easy task without HP. I want to build it right and big the first time. Where do I start and how big can I go? I feel nothing less than a 100 hp is what it's gonna take and bigger is always better at least where I pull at. Any suggestions of a good guy that builds these engines or where I can start would be helpful. Thanks
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2015 at 8:59pm
To get 100 hp, you are going to have to go to a stroked engine.
Try to contact Marty Nelson (wi50). He occasionally has some stroked 201's for sale.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2015 at 10:18pm
It just takes money.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote 48ACWD Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2015 at 5:15pm
I'm game for whatever it takes. Around here guys look at you strange for pulling in at the pulls with a orange tractor and I wanna give them something to watch on the track. I have a bare clean wd 201 block to start with either myself or a professional builder could get started on it. I'm not certain on what I would be looking at cost wise in a way it don't matter as long as I get what I'm looking for in the end. Do they make a stroker rotating kit for the 201 like I got for my small block mopar when I built it or does everything get pieced together as you go. I was able to build my v8 with basic engine building knowledge cause the kit came with all you needed to achieve the 500hp.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2015 at 7:13pm
So, money is no object ? If you want reliable, useful information, tell us about the speed limit, and all other pertinent rules your pulling with. I've always put together tractors to fit the rules, and let the tractor decide what weight class it felt frisky at, and I seldom was disappointed. Every setup has a sweetspot that it prefers, and HP is only as useful as your traction and balance and ability to guide it down the track.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2015 at 8:59pm
At least start with a very late model WD block, that is solid above the center main bearing saddle. WD-45 block is better. D-17 block/crank is the best.
