720 Hydraulic Lines
ShaunE View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote ShaunE Quote  Post ReplyReply Direct Link To This Post Topic: 720 Hydraulic Lines
    Posted: 13 Sep 2015 at 9:44am
I have recently added the final two front hydraulic lines thanks to D-17Dave.  However the lines I added were from a Simplicity Powermax.  That being said, I need the short extensions that bring the couplers at that downward angle out the front bracket.  The ones I need are for the LEFT side as you are facing the front of the tractor.  I believe they are going to be longer than the ones I have on the right side as the lines that go to the LEFT side are located higher in front of the battery.
I hope that makes sense.
Thanks
Shaun
Edited by ShaunE - 13 Sep 2015 at 10:05am
mnoonan-NEWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnoonan-NEWI Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2015 at 9:54am
Shaun,
I have the 4 factory hydraulic lines on my 720 and have a couple of close up pictures I could email you.
Mike
AC CA, Ferguson TO-20, Ford NAA, M-M BG, AC #3 Mower, SC Plow, PH Digger, AC 720's with Ark 700 loader & Brantly Backhoe, "Mini B" w/flathead Ford V8
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote ShaunE Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2015 at 10:01am
That would be great.
Thanks
PM Sent
Edited by ShaunE - 13 Sep 2015 at 10:49am
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote ShaunE Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2015 at 11:51am
After seeing Mikes pictures, I see the lines going to the left have a slight bend in them to compensate for the height difference.  So the short extensions are all the same length.
hopefully they will be easier to come by.
Thanks Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2015 at 6:42am
I'll take a look at mine because I installed new fittings up front, and I don't remember what I changed on mine. I might be able to fix ya up with the fittings like I used. Let me take a look tonight. If I remember correctly, my fittings both come out at the same length side by side of one another. One isn't higher or out farther than the other that I can remember...
Steve@B&B
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote ShaunE Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2015 at 7:30am
Thanks Steve.
This page was generated in 0.328 seconds.
