recommended engine oil for hd5
serioussam View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote serioussam Quote  Post ReplyReply Direct Link To This Post Topic: recommended engine oil for hd5
    Posted: 10 Sep 2015 at 2:41pm
What is the recommended summer and winter engine oil for the hd5 thanks
gemdozer View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2015 at 4:06pm
For summer time sae 30 and winter time sae 10  for HD5 DETROIT 2 CYL.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2015 at 10:11am
I have been using 15 x 40 Shell Rotella for many years .
A good multi-grade heavy service oil, Might add some STP or other zinc bearing additive also as most new formula oils are missing that element from them.
 New Diesel oils are formulated not to meet EPA rules for Tier 3 and Tier 4 engines or engines with cat converters and much is missing .
Eric B View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2015 at 11:45pm
If you have any issue with oil consumption you can use SAE 40. Most of my trucking career I used the 40W for my Detroit 2-cycle engines with good results (bought it at Walmart most of the time). If you have cold winters and you're still dozing you should go thinner. I used the 40W down to 20 deg. F., of course I had the block heater plugged in and sometimes the oil pan heater. I watched an oil testing demo (for metal to metal protection) once. The 40W gave the over all best results.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2015 at 9:45pm
Guess since oil pressure was nuttin to be proud of on them 2 strokers, I had heard that you was supposed to run 30 weight in the winter, and 50 weight in the summer. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2015 at 11:30pm
15x40 gives me about 15 psi idle 40 + running
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2015 at 1:35am
I've been told by Detroit specialists that if your engine (Detroit 2-cycle) does not maintain 30 PSI oil pressure at full RPM and hot, the bottom end is at risk. They don't seem too concerned about the oil pressure at idle if at least you have 5 lbs. due to the volume from these pumps.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2015 at 11:15pm
I always ran Rotella 15-40 in my HD5
This page was generated in 0.172 seconds.
