wd engine and marvel carb
Justin82 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Justin82 Quote  Post ReplyReply Direct Link To This Post Topic: wd engine and marvel carb
    Posted: 09 Sep 2015 at 8:30pm
hello to all,
new member here that needs advice. I am running a wd motor with a 45 crank 4.125 flat top pistons and custom cam. I want to run 2 gear in 4500 class with 14.9x28 tires. should I stroke to 5" and cut the pistons or go with a different combo. The carb is a marvel with no ID tag, the air intake has a 1 5/8" ID if this helps. I built this motor 13 years ago and stopped pulling after 3 years until now so I cant remember the cam specs. The cam was done T.Richardson in NC. or SC.
Thanks for all your help.
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2015 at 9:10pm
Any reason in particular you want to run second? Not paced pulling?
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote Justin82 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2015 at 9:19pm
Yes some pulls are divided in to divisions and I would just like to trie something different.
Brampton 02 gt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2015 at 9:59pm
I would think you could run second with that combo and spin out more often than not.  Is it dying in second?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Justin82 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2015 at 2:57pm
Yes it will die out in second but will not die out in first even standing on the brakes. I am just looking for that extra hp in second but not go to radical on the engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2015 at 3:51pm
What does a cranking compression test reveal for numbers??????
Post Options Post Options   Thanks (0) Thanks(0)   Quote Justin82 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2015 at 7:31pm
I have not done a compression test yet but I will and let you know. Is there any way to tell witch marvel you have by appearance or measurements? When I bought it from an old allis dealer used I was told it was a gleaner carb. It also has electronic ignition from Denny's carb shop if that makes a difference.
mgburchard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mgburchard Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2015 at 9:39am
Jt ran a usx series carb on his allis .
Post Options Post Options   Thanks (0) Thanks(0)   Quote mgburchard Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2015 at 9:45am
If you have a Facebook account go to allis wc @ wd pulling engines. You will find a fellow by the name of Brian Morrison there he does what your wanting to do but does it in third gear with 38 tire
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2015 at 9:46am
Like a USX21 from a JD?
You are being cryptic
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote mgburchard Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2015 at 10:14am
Like Oliver usx 29 think the deeres a 21
Post Options Post Options   Thanks (0) Thanks(0)   Quote Justin82 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2015 at 5:56pm
Did a compression test tonight and 150psi across the board.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2015 at 9:54pm
150 psi isn't much when it comes to pulling. A standard D-17 engine has 145 psi per AC Service book. A standard 170-175 engine is 170 psi or a little more. You could stroke your engine provided there is no ring edge in the sleeves, and get that compression up to 240-260 psi would help a bunch. Might want to consider using newer connecting rods from a late D-17 or 170 or have yours heat treated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Justin82 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2015 at 10:40am
If I get my rods heat treated what Rockwell do you recommend, and would I have to do any machining on them or would they maintain their tolerance?
