HD11-E Final Drive Seal Kit
bass100 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass100 Quote  Post ReplyReply Direct Link To This Post Topic: HD11-E Final Drive Seal Kit
    Posted: 08 Sep 2015 at 2:12pm
Does anyone know where i can lay my hands on a Final Drive Seal Kit for an HD11-E....From what i can find....the seal kit for an HD11, or HD11-B will also work.
Please email with any info you might have.....  bass100@earthlink.net
thanks Bob
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2015 at 4:56am
if anything is available http://minnpar.com will have it.   they had the gaskets for my 16 final.  dont know about the rubber "bellows" on the spring loaded side, mine were still good if only uncemented on one side
go to the parts books here( http://www.minnpar.com/manuals.asp )  and look under allis chalmers construction/ dozers  for part numbers
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2015 at 2:13pm
A year or so back I checked with Minnpar on a seal(same one) for my 7G, they had zero and access to zero, none in the works as fr as they were aware as only AC used them, I did a p/n search as a internet search and located but one in CA with no other hits and bought it.  I suspect from here on out we will need to look at some sort of machining to fit some other form of seals or approach some manufacturer as to making them anew.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2015 at 2:34pm
I am still have 1 new seal kit for the outboard bearing cage for HD11
Lazyts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2015 at 10:42am
You'll want to check serial number.  Older models have 3/4" seal rings for inner sprocket seal, later models have 1/2" seal rings- change occurred around 13000 serial number I think...  Minnpar should have seal rings, or they can often be re-used if in good shape, you should still be able to get the boots and rubber gaskets.  I just finished doing a final on an old 11E a couple of months ago.  I do have a couple of new inner (old style) seal rings.  As far as I know the complete "seal kit" is no longer available.
