720 Front axle's |
mnoonan-NEWI
Joined: 11 Sep 2009 Location: Marinette, WI Points: 739 |
Topic: 720 Front axle'sPosted: 07 Sep 2015 at 8:34pm |
Was there a heavy duty front axle and a normal duty front axle on the 720's. I have (2) 720's and one has bigger steering arms on top of the spindles?
AC CA, Ferguson TO-20, Ford NAA, M-M BG, AC #3 Mower, SC Plow, PH Digger, AC 720's with Ark 700 loader & Brantly Backhoe, "Mini B" w/flathead Ford V8
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12071 |
Posted: 07 Sep 2015 at 10:29pm |
Yes, from what I've heard on here a while back, there was an upgraded front axle which was heavier. Don't know when in production they were introduced though...
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4078 |
Posted: 07 Sep 2015 at 11:24pm |
think the spindle diameter is still the same size with the bigger steering arm ontop have to mesure the 720 parts tractor and the 616 had both side by side a week a go swapping hyd valves and starerter soliniod and the pto to the 720 without the carrier bearing front axles looked the same to me but i found little differances all over the two tractors that had been changed from the 616 to the 720
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10939 |
Posted: 07 Sep 2015 at 11:27pm |
I don't have my parts book, but IIRR that is correct. Just a heavier steering arm and thread on the end of spindle.There was a service bulletin to add a plate for the axle pivot bolt. HTH Tracy
Edited by Tracy Martin TN - 07 Sep 2015 at 11:27pm |
HudCo
Posted: 07 Sep 2015 at 11:33pm |
should have checked for up grades while i had my engine out on that piviot it is alll nice and tight and i did check to see witch way the bolt was so it could be removed without lifting the engine
mnoonan-NEWI
Posted: 13 Sep 2015 at 9:44am |
Thanks fellas,
I have done the upgrade to the heavier front axle. Without pulling the engine, I had two buddies to help. It pretty much needs more than one man.
