Hd4 parts needed
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Topic: Hd4 parts needed
    Posted: 07 Sep 2015 at 4:04pm
Guys I am looking for the shuttle clutch control valve for an HD4. This is the valve on the left hand fender that you shift for forward neutral and reverse. Got a dozer here I can get good pressure to it but nothing out of it. Yes I have had it apart. It is beyond repair
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2015 at 5:57pm
Sumerix Equipt. should be able to help. Might try Blount epuipt. in Hoboken, GA. HTH Tracy
Randaleky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2015 at 7:24pm
IS IT JUST THE SPRINGS BROKEN OR DAMAGED TO WALLS OF THE VALVE BODY ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2015 at 11:12pm
Beyond repair ? center neutral - and 2 ports hold - should be able to find a valve - say surplus center - aftermarket . Or have yours rebuilt - see if Minnpar has pieces to rebuild .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2015 at 5:03pm
Thanks for the tip Tracy. I will check them out
1968 D15D,1962 D19D
This page was generated in 0.563 seconds.
