wc pulling advise
JM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JM Quote  Post ReplyReply Direct Link To This Post Topic: wc pulling advise
    Posted: 17 Apr 2010 at 1:50pm
I have found a set of 15.5-38 tires and a set of 16-38 wheels. I am pulling in a 3 mph.class, should I even try to pull without lower gears? I know I will be idling until I get some slip. Or, should I put more into the engine,like stroking it out to 5 or 5.5 and run stock gearing?The engine is basicly a d17 build with some head improvments, I will pull in the 3500-4000 class. Thanks, JM
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2010 at 2:15pm
Engine and more  speed from taller tires. sled always wins never enough horsepower but kinetic energy helps.
Edited by mlpankey - 17 Apr 2010 at 2:17pm
KevinC(MD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinC(MD) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2010 at 8:46pm
My advice in a 3 mph class is WD45 type horsepower (stock) is sufficient as long as you are running 28 inch rubber.  And I would run 28 inch rubber, here's why:  it is much easier to find traction with short tires (23 degree, 26 vs. 28 inch, old vs. new tires, 13.6 vs 14.9 etc.) than it is to find the horsepower to make those big wheels turn.  Sure, there's gearing changes (D17 diesel type) andstroker motors etc., but there is a lot to be said about the Allis set-up from the factory.  3mph is slow, and I can make 28 inch rubber stick to a track.  I've recently switched to a 13.6 from a 14.9 (unheard of) and have had good results with a wide rim (no wider than tire) to get that tire to work.  My experience with the short tire set-up began when I got my rear end handed to me by a WC with 26 inch combine rims and 14.9 /26 rubber.  Hope this helps, but as always it is just a good hearted suggestion.  When I'm suffering in the traction department, it is almost ALWAYS hitch height and length that was my mistake...not the tire size's disadvantage.  Good luck and have fun.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2010 at 9:05pm
I agree with Kevin. Won many trophies with a bone stock D17 and 16.9x28 tires against hopped up Ollies and Deeres in the 6,500 and 7,500 lb classes as I didn't want to take the fluid out. Unlike the competition I actually used my tractor after the pulls. I would say that my old CO-OP tires were easier to find the traction with than the long bar short bar I replaced them with but I figured them out eventually. I stayed away from slippery gravel tracks and stuck to sticky clay or black dirt tracks.
Edited by Lonn - 17 Apr 2010 at 9:07pm
Wink
I am a Russian Bot
This page was generated in 0.172 seconds.
