653 loosing dexron out of the torque housing
B52FXR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B52FXR Quote  Post ReplyReply Direct Link To This Post Topic: 653 loosing dexron out of the torque housing
    Posted: 05 Sep 2015 at 6:08pm
I have been working on my dozer and I am trying to understand the operations of how everything work. I am loosing mass amounts of transmission fluid out of the torque housing. What might be causing this problem. Any help would be great!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2015 at 10:02pm
leaking clutch pack , bad seal on torque converter ,  broken line or ?
Randaleky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2015 at 10:14pm
check the transmission and see if it is overfull. could be seal between tranny and torque housing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote B52FXR Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2015 at 10:25pm
I crawled under it and saw the fluid at the bottom of the transmission/torque converter housing. I don't quite know how to go about checking it...........but I am trying to learn. I don't have pressure guages yet...............but I will get some soon. Thank you all. I will do my best to keep you informed how its going.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2015 at 10:29pm
check the dip stick for the tranny for overfull. also there are lines for the cooler and return lines back into the torque housing on the side. the sump line is also located on the left side of torque tube as sitting in the seat. belly pans will need to be pulled of if not already done. you will need to clean the bottom good and start it ( make sure it is blocked against motion first ) and see where it is leaking. could just be a ruptured line. i hope that is all.
Josh H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh H Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2015 at 5:52pm
I had to replace a short section of rubber hose inbetween two steel pipes on my 655, on the bottom side. I believe there are two under trans. Above cross section of frame. Hard to get to as i remember
Post Options Post Options   Thanks (0) Thanks(0)   Quote B52FXR Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2015 at 8:15pm
Thank you all for your help..............I will be taking the belly pans off this week once I get it pulled up on some crossties so that I can get under it safely.I hope maybe it is just lines leaking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote B52FXR Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2015 at 9:30pm
dexron fluid coming out of the torque tube housing and the transmission at the bottom of the splitline of the two cases. I am sure I am going to have to pull the torque converter housing and engine to find the leak internally. I am frustrated...............but I want to see her back on her feet and doing her job. Thanks for any input from all of you. Thanks a million!!!!!
