620 Front Hydraulics |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Topic: 620 Front HydraulicsPosted: 04 Sep 2015 at 10:35pm |
Today I put the front mounted snowblower on the front of my 620 since I bought the package 5 years ago. However I have a problem. The hydraulic cylinder does not lift up the snow blower, it only pushes it on the ground more (raising the front axle off the ground). I tried switching the hose connections at the front of the tractor, but it makes no difference.
The remote ends on the tractor are brand new and the balls on the male connectors move when pushed (one squirts oil out, the other doesn't). It seems the lift control does not do any thing when you move it to the lift position (pull back towards the operator). It works in the lower position. However, there were times that the cylinder would not move when set in the float position. To me, it sounds like a problem with the connections at the front of the tractor. Any Ideas? ![]() |
sparky
Joined: 13 May 2011 Location: So. Indiana Points: 1834 |
Posted: 05 Sep 2015 at 10:17am |
Would one of the lines have unbled air in it? I don't really know but just guessing. Good luck.
farmtoybuilder
Joined: 11 Sep 2009 Location: Dresden,Ohio Points: 1457 |
Posted: 05 Sep 2015 at 11:30am |
You should have oil flow out each when you move control valve to either position. If you don't, Valve has a problem. Which is odd for spool type valve.
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4078 |
Posted: 05 Sep 2015 at 4:15pm |
try hooking up your three piont cylinder and see if it works if it does the packing ont the piston in cylinder is blown
DSeries4
Posted: 08 Sep 2015 at 9:54pm |
Problem solved! One of the hose couplers on the snow blower was slightly shorter and would not fit into the remote all the way. I like easy fixes!
macvette
Joined: 13 Jun 2011 Location: nekoosa, wi Points: 1658 |
Posted: 09 Sep 2015 at 12:08am |
That was a real blessing in disguise.
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12071 |
Posted: 11 Sep 2015 at 12:41am |
Myron,
That's a pretty serious snow blower man! You'll move some snow wit' dat! |
DSeries4
Posted: 11 Sep 2015 at 9:51pm |
