how much horsepower
autobody View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote autobody Quote  Post ReplyReply Direct Link To This Post Topic: how much horsepower
    Posted: 02 Sep 2015 at 8:41pm
How much horsepower will a 4.5 bore 6 inch stroked d 17 engine turn the head has big vavles and has been ported.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2015 at 5:27am
That measures to be 382 cubes. If you maintain the same efficiency as the original D-17 engine at 53 HP, you should have 90 HP. Of course, you give zero information on compression ratio, camshaft grind, or carburetor size.
Post Options Post Options   Thanks (0) Thanks(0)   Quote autobody Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2015 at 6:54pm
Compression 12.1 cam regrind 190 duration vavle lift .532 carb ms tsx 916
mgburchard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mgburchard Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2015 at 12:17pm
Compression is good I would hope 190 is at .050 on cam with a bigger carb you should break the PTO at 100hp and who knows if its 20 more or 50 more after that.
