200
Chuck C View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chuck C Quote  Post ReplyReply Direct Link To This Post Topic: 200
    Posted: 16 Apr 2010 at 12:36pm
HI All, our 200 has a somewhat rough idle and seems to miss at higher rpms under load. We've changed filters, what's next. Any ideas, comments or suggestions would be appreciated.
             Thanks,   Chuck
SIMPLICITY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2010 at 9:09pm
the cam ring in the fuel pump may be bad
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2010 at 5:41am
Consider removing the shut-off valve from the bottom of the fuel tank and cleaning it. Let some fuel run out on the ground while you hand the valve to someone else and have them blow thru it both ways....common probkem on a 200.
