Wc Motor build
Message Reverse Sort Order
Robacpuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robacpuller Quote  Post ReplyReply Direct Link To This Post Topic: Wc Motor build
    Posted: 07 Apr 2016 at 8:41pm
I built a 400 cube wc puller. I have a 6 inch stroked crank and 4.600 bore, big block Chevy pistons. I used 8 inch rods from a 350 international. The head is wc head ported and polllished. I have big block Chevy valves, 1.92 intake 1.60 exhaust. Intake manifold is stock but port matched to head. Carb is d17 bored to 1.40, no choke. The cam was ground notched to fit rods.the rods and bearings were narrowed to fit crank. The crank and rods were done by Keith Merfeld. I had to grind the block for Clarence the rods I had to modify oil pan. I am running 11 to 1 compression. I used a D17 block and crank. I could not Dino it because drop boxes kept breaking. We figure it to b around 100 hp. I have 15.5 tires, never ran out of power but need to get bigger tires. The slaves we turned down .o26 on bottom of sleaves , we bored block to fit sleaves. Used the green sleave sealer from lock tight. Pressed the sleaves in never had a problem with leaks. We o ringed the top of block with a stainless steal .052 wire, I used a copper head gasket no leaks.
mgburchard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mgburchard Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2015 at 10:31am
Leeoi head has around a 180 cc chamber so to make anything out of it Pankey recomwmnds stroke of 6.25 with 8 inch rod like came in the lerio that had those heads and a automotive piston and dome to set compression to a desired level
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2015 at 8:41pm
You might find a taller piston and cut it down to what you want.  MACK
ksbowhunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ksbowhunter Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2015 at 7:49pm
Originally posted by CAL(KS) CAL(KS) wrote:
H farmall rods would be simple and much cheaper than custom. we have some going onto a 5.4 crank but your piston choice with the leroi head may require something different depending on compression height/ piston type
I was thinking the H rods also but am having issues finding a 1.9 compression height piston in automotive at 4.125, If I go with an 8.5" rod I can use a 1.4 piston that are easy to find.
2-37 WC
37 wf127
37 wf130
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2015 at 4:04pm
Edited by CAL(KS) - 31 Aug 2015 at 4:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ksbowhunter Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2015 at 3:18pm
I don't right now. Its at my dad's house right now. I am going to get it from him in a couple of weeks.
2-37 WC
37 wf127
37 wf130
bigcountry48 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcountry48 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2015 at 2:35pm
Not sure about rods, but do you have any pictures of the head? I've never seen one of those before and I'd like to look at it.
1950 B, 1952 pulling wd, and 1954 wd45
Post Options Post Options   Thanks (0) Thanks(0)   Quote ksbowhunter Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2015 at 11:45pm
Hello, I am looking for some information. I currently have a Leroi D226 head with the combustion chambers in the head. I am wanting to know what rod would be the best to use at 5.5" stroke?
Thanks.
2-37 WC
37 wf127
37 wf130
