Winch options for a HD5 |
serioussam
Topic: Winch options for a HD5Posted: 30 Aug 2015 at 7:51am |
Looking at getting a winch for the HD5 and would like to know what my options are
Thanks for any input |
gemdozer
Thanks(1)
Posted: 30 Aug 2015 at 2:53pm |
The hd5 and hd6 and td9 used the same winch model
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42268 |
Thanks(1)
Posted: 30 Aug 2015 at 2:58pm |
One problem is they are driven by output shaft on transmission - and if you have loader that means counterweights would block access .
One option might be to go to unit with a hydraulic motor . Also as winch is transmission driven - it would mean clutch engagement when winch is used . |
donoman
Joined: 18 Feb 2015 Location: New Zealand Points: 117 |
Thanks(1)
Posted: 30 Aug 2015 at 3:09pm |
your best option for a HD5 would be a Carco E24 or EA an Issacson WO6-9 is similar to the EA and was also fitted to TD6 and TD9'S
serioussam
Posted: 30 Aug 2015 at 8:52pm |
I might be getting a winch off a TD9 , also what else am I going to need to make this thing work on the hd5
Thanks again for all the help |
Mactractor
Joined: 20 Jun 2011 Location: New Zealand Points: 652 |
Posted: 30 Aug 2015 at 11:30pm |
If I recall correctly, Allis has a different drive shaft to IH. There is a slight difference in the mounting stud pattern between the two makes of tractor. Ive used Carco from IH tractors on HD6
donoman
Posted: 31 Aug 2015 at 2:05am |
I fitted a WO 6-9 Issacson to the Buda HD6E I purchased in 1974 ,it bolted straight up, I think there is a difference in driveshaft length, although the splines are the same, I recently acquired a E 3O Carco winch believed to be off a TD9 I had to lengthen the shaft to make it the correct length.
