how to check true rpms
screwloose View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote screwloose Quote  Post ReplyReply Direct Link To This Post Topic: how to check true rpms
    Posted: 29 Aug 2015 at 1:31pm
New tach, new cable, original gears and original pulley and at idle it read 1,100 rpms, at about 3/4 throttle it read pegged. Mack told me the original pulley was worn out. He was correct. Bought a new pulley and you wouldn't believe the amount of wear on the old one now that I can compare the two. But, I still think the rpm reading is a tweak off. Idle read 800, when I rev it up to what the tach says is 1,900 rpms, 540 pto speed, the engine sounds to me like its only about half throttle lol.
How can I check what the true rpms are so I can compare that to what thd tach is reading?
Post Options Post Options   Thanks (0) Thanks(0)   Quote screwloose Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2015 at 1:34pm
Hold on a minute, I forgot something. It's a 190xtd
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2015 at 1:37pm
If I have a guys tractor here at my   shop .I Hook the tractor to my Dyno and go by where tractor tact is reading to the PTO RPM's
Edited by Fred in Pa - 29 Aug 2015 at 5:48pm
nonetheless ,still dead.
Brian-KS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian-KS Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2015 at 1:46pm
EAT BEEF!
Post Options Post Options   Thanks (0) Thanks(0)   Quote screwloose Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2015 at 1:57pm
So a dyno tells you the pto speed?
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2015 at 3:58pm
hold a RPM gauge on the end of the PTO shaft....Napa sells them
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2015 at 4:00pm
or with the radiator off, hold the gauge on the center of the crank pulley!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2015 at 4:29pm
Dynomometers all have a tachometer on them and it should be a good one, because HP rating are at a given PTO speed. Tractor tachs are generally NOT that accurate. Go by the specs in the Dyno Operation manual to have correct engine/PTO speeds.
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2015 at 6:14pm
Mark
GTH-L Simplicity
CALEBnOK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CALEBnOK Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2015 at 8:50pm
Originally posted by 427435 427435 wrote:
http://www.harborfreight.com/digital-photo-sensor-tachometer-66632.html
I use my laser tach all the time. Has a center attachment and a wheel if you put in the diameter of whatever your driving it with. I also have a caterpillar tach that uses a clip on a fuel line so you read the pulse of the injection line. Can use it the set three engines side by side at one time all by look at the gages in the box
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2015 at 9:40pm
427435 has the best way to check RPMs. Can be used on any thing that turns that you can put a piece of tape on. MACK
wayneIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayneIA Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2015 at 9:52pm
My M&W dyno tach is off about 40 rpm at 540, I checked it using a photo tach.  Just a word of warning that you still need to know if the dyno tach is correct if you are going to use it to check your tractor rpm.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2015 at 12:45pm
20 years ago I bought a photo tach but back then I think I paid over $100. If you get one, take the batteries out when you're not using it. Ruins your tach if you leave it too long without use and the batteries start leaking. I found out the hard way. It's on my list of things to take apart for a looksee.
Wink
I am a Russian Bot
