Pictures of a D17 front-mounted pump setup
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Topic: Pictures of a D17 front-mounted pump setup
    Posted: 15 Apr 2010 at 7:54pm
Hi All!
I'm working on a D17 Series 1, and need low-pressure/high volume live hydraulic power... wondering if anyone has a similar machine with a front-driven hydraulic pump... if so, would you mind posting or sending pictures, and telling me about how it's done?
Specific questions:
I see there's a crank-access hole in the aft end of the radiator shell/power steering area in front of the crankshaft pulley.  I DON"T see a hole through the tinwork in the front... do guys just hole-saw through there, or what?
LOOKS like the front crank pulley has bosses that'll accept bolts for a plate-type coupler... is this how people do it, or is there a better/wiser way... was there a special coupler, or a different drive sheave made to suit front-end PTO applications?
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2010 at 8:14pm
 yes you can buy couplers  have sold many for repairs   1-800-254-3116
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2010 at 8:23pm
There should be a knock out for the crank hole in the front shroud.
