HD11E return spring for brake
Gargoyle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gargoyle Quote  Post ReplyReply Direct Link To This Post Topic: HD11E return spring for brake
    Posted: 26 Aug 2015 at 11:01am
My left steering brake had a wonderful bungee cord acting as a return spring. I think that Earl Scheib owned this thing before I did.
Those springs are fairly stout and I can't see a  way of getting enough leverage on a replacement spring to get it into place.
Aside from putting on a new bungee to replace the one that broke, is there a better fix? Or is there a trick to getting that spring on?
dustydoo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustydoo Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2015 at 4:27pm
the easiest way I have found to attach a stout spring is to hook one loop of the spring in place the loop a length wire a couple feet long to other end and then you can pull the spring with quite a bit of leverage
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2015 at 7:03pm
I actually have a truck air brake return spring set of pliers, works great for these as mine on the 7G are similar.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gargoyle Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2015 at 9:41am
I'll see if I can track down a set of those pliers.. If not I'll try the wire trick..
