wanted single front wheel WC
Adam from shoe fly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam from shoe fly Quote  Post ReplyReply Direct Link To This Post Topic: wanted single front wheel WC
    Posted: 15 Apr 2010 at 7:00pm
Would like to purchase a single front wheel for a WC, is this the same as WD and WD45. Thanks for any info.
Daveo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daveo Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2010 at 7:10pm
I have one.
Dave
Ib4u61@comcast.net
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam from shoe fly Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2010 at 2:40pm
Is the block yoke and wheel the same as the WD and WD45, Thanks for any information.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2010 at 2:55pm
The WC and early WD single front wheel is all one piece. Later WD's and WD-45's have a two piece set up where the fork is attached with 5 bolts. The casting that contains the steering gears etc is the same for single front, wide fronts, and you can also bolt on the dual front conversion pedestal for mounted corn pickers.
