Planter plate selectors
Chris (swIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris (swIA) Quote  Post ReplyReply Direct Link To This Post Topic: Planter plate selectors
    Posted: 15 Apr 2010 at 6:35pm
I have a set of AC planter plate selectors and I was wondering how they were used. Are assume that there are more than 1 set made for different seeds. Do the numbers next to the slots correspond to plate numbers or sizes or what? I was just wanting so info on them. Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2010 at 8:55pm
I have never heard of planter plate selectors. If you are talking about planter plates, yes there were different sizes for different seeds and several sizes for different grades of corn seed. In the old days a medium flat was a common plate as it was a common size of seed corn. I don't know what numbers would be on a plate.
Wil M (NEIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wil M (NEIA) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2010 at 9:24pm
These are the 2 seed plate selector guides:
They are used to measure the seed size in order to determine what seed plate you need for a plate planter.  A rear mounted planter owners manual tells you how to use them and how to interpret what planter plates you will need. Basically the cell number on the selector plate correspondes with a cell size and plate number and number of cells in each plate for the plate needed. This than can also be cross referenced witn the seed being planted and what plates may be used.
Wil
Edited by Wil M (NEIA) - 15 Apr 2010 at 9:28pm
"Yet there are soulless men whose hand and brain tear down what time will never give again." Anderson M Scruggs
