Cement for rear oil seal
BobDinNC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobDinNC Quote  Post ReplyReply Direct Link To This Post Topic: Cement for rear oil seal
    Posted: 15 Apr 2010 at 2:39pm
Is there a locally available substitute for 3MEC-847 cement that is listed to be used on the rear mail oil seal (D17 series I)?  The manual lists a part number (921164) but I don't know what this stuff is?  Can I get something at NAPA that will work?
ALinIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2010 at 3:07pm
Bob - I believe it's the same as weatherstrip cement.  Don't quote me but someone may come on with the correct glue. - AL
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2010 at 3:13pm
bump  -  mfg by 3M
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2010 at 3:55pm
3M 08011 weatherstrip adhesive, you can also use contact cement,  Weldwood? in the little brown glass bottles with the brush in the cap ,
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobDinNC Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2010 at 5:24pm
Am I correct in assuming you are referring to automotive weatherstrip adhesive and not household weatherstrip?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2010 at 5:30pm
The weatherstrip cement is the automotive type.  Is usually yellow to dark tan in color.  Sticky stuff , sort of like snot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2010 at 5:51pm
Part # above is for black, yea its sticky.
